![]() Join Date: Jul 2016
Cab and Bed cuts
From $75 shipped.
I do have both side bed taillight cuts available. $175 shipped per side on those. If you need both side then $300 shipped. Drip rails $85 per side shipped. Good windshield corners. Ac box firewall cutout for template or to weld in, $75 shipped. Uncut dash panels, side to side with upper dash, cut on far side of pinchweld, $175 shipped. Some good firewall cuts. See pics of body in my 72 k10 parting thread. |
![]() Join Date: Nov 2010
Re: Cab and Bed cuts
Do you have a good bed floor? My 72 the steel bed is rotted
LH bedside cut from topside of marker light to wheel opening to bottom edge. Outer skin only shipped to 30530/.
im interested in the passenger side tail light cut. if possible can I see a picture? Thanks in advance, Clark.
[QUOTE=dec010974;8587848]im interested in the passenger side tail light cut. if possible can I see a picture? Thanks in advance, Clark.[/QUOTE
Pics tomorrow |
Pics
More
Few more
Both tail lamp areas are good, driver side lower has rust just behind the wheel opening, prob same on other side.
The red and white driver side tail lamp bed cut is pretty straight. I think the drip rails are useable, probably light pitting. |
Bed floor has rust forward right floor area and a few other spots.
#13 |
Green bed for cuts, driver side tail lamp area is damaged, the rest is ok.
Passenger side is pretty nice. Top rail on on one or both sides is rusty, if you need the whole rear corner cut will need to verify condition. |
#14 |
How about the green bedsides?
#15 |
#16 |
![]() Join Date: Feb 2018
Hi, I need pass side drop rail. When can you ship?
#17 |
#18 |
Hi Randy,
Would you have some solid inner roof patch panels highlighted in the attached picture? I need both right and left side panels above the doors from (including) the pinchweld flange at the rear to a couple inches behind the big sunvisor hole at the front and from (including) the pinchweld at the door frame to maybe an inch into the depressed area in the center of the inner roof panel. You could cut just outside those areas and I will trim to fit. Thanks. Randy S. |
#19 | |
#20 |
Thank you.
#21 | |
![]() Join Date: Jun 2017
#22 |
#23 |
#24 |
Here it is, looks good, not sure of flat rate box sizes but if 12 x 12 fits one then this is $75 shipped. Cant cut it until soonest late next week.
#25 |
Are you trying to use the 2 edges with bolt holes? Also is 12” going to run into a crossmember?
