09-05-2019, 12:22 AM | #1 |
Can someone tell me how many teeth for my speedo gear '69 C20 TH400 350 w/4.10s
The trans has been swapped at some point in my truck and I want to make sure the correct speedo driven gear is installed. '69 C20 350 w/ turbo 400 and stock 4.10 rear. Build sheet says the stock gear is "JE" code. Anyone??
Thanks, Steve weim55 Colorado |
09-05-2019, 08:32 AM | #2 |
Re: Can someone tell me how many teeth for my speedo gear '69 C20 TH400 350 w/4.10s
What do you mean by correct?
Correct as in original or correct as in accurate! You’d need the driven gear teeth number too. |
09-05-2019, 09:17 AM | #3 |
Driven gear, yes. Need a starting point and hopefully the original will be correct. It currently has a 36 tooth gear. Running a stock height tire. Original tire was a 7.50 16.
09-05-2019, 09:21 AM | #4 |
Maybe you could reverse engineer it.
Use a calculator found in here. https://transmissioncenter.net/ |
09-05-2019, 11:22 AM | #5 | |
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
09-05-2019, 10:09 PM | #6 |
Here you go fellas. Allow me to post a direct link to the speedo gear calculator to make it easier for forum members to find.
http://www.bgsoflex.com/speedo1.html |
