Old 09-06-2019, 12:24 AM   #1
Magicalzoomer
Wheel Tire Size and Drop
Can anyone give me a rough estimate of the wheel and tires size of this amazing 67? Is he running a 3/4 drop? Would love to get a similar look. Especially the tire height.
https://www.youtube.com/watch?v=HUXyJRX8LvIhttps://www.youtube.com/watch?v=HUXyJRX8LvI
Could I run the following without rubbing and still tuck? Any advice would be greatly helpful
Rear
16x10
4 inch backspacing
Front
16x8
5.5 inch backspacing
Magicalzoomer is offline   Reply With Quote
Old 09-06-2019, 01:30 AM   #2
cornerstone
cornerstone's Avatar
Re: Wheel Tire Size and Drop
My guess is at least a 5/7 static drop or an air ride syetem with boxed lower A-arms in front and 2" drop blocks in the rear. Looks like a 15" wheel to me.
Very slick truck.
In the words of Forrest Gump..."Thats all I have to say about that."
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 09-06-2019, 07:22 AM   #3
Mike C
Mike C's Avatar
IMO, you would want 4.5” bs in front and 5” on rear. Maybe 5.5” if your truck is a fleetside, that would be zero offset.
I don’t think even with a 16” wheel you will clear the control arm with 5.5” bs and that will tuck the wheel in too far.
My truck has 235 55 17 on front on a 17x8 4.5” bs wheel with no rubbing issues. 2 1/2” spindle disc conversion and 2” spring. I have 17x9” 5” bs on rear with 275 55 17. Stepside leafspring truck with flip for 7” drop.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-10-2019, 08:51 AM   #4
68Stepbed
68Stepbed's Avatar
I'm about 99.9% positive that's a 4/6 drop with 15x7 wheels and 235/75/15 tires. The wheels are actually 88-91 Blazer/Suburban wheels that are painted or powdercoated black. I could be off on the tire size, but that's a very tall and skinny tire.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
