FUEL CELL GURU
More progress.....
before.
FUEL CELL GURU
After....
Just need to add the shiny parts to complete the look. Won't be long....
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Look's good!!!! That's coral correct and not pink?? Look's like the truck is comming together quickly..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
![]() ![]() Join Date: Jul 2002
Looks good. Hopefully you'll be able to Cruise this way next year with it!
FUEL CELL GURU
YES!!!
I already have my registration form printed out. Cruisin' the Coast 2004. I will be ready and so will the truck. I don't think I have to worry about any flat cams this time. I am ready to go already. The color is called Tropical Peach. I only like it in natural light. Under flourescent lights in the shop it looks pink. I don't know how many customers ask me, "Who's PINK truck is that??". Naturally, my response is "It is not pink!". Oh well, you should see it in the flesh in October, Palf. Looking forward to meeting up somewhere down there. Later, FCG
Umm with the flat cam problem did you break them in ? Just wondering.
Sweet motor.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
FUEL CELL GURU
Well...
I found out why not only one but two cams went flat after normal break procedures. I sold the engine to a buddy of mine and he has decided to rebuild it again. When they were disassembling the engine, they found a rod bolt that was only finger-tight. I knew I should have checked EVERYTHING before I buttoned it up. The loose bolt was letting oil past the bearings and starving the cam for oil. Therefore, premature cam failure. If you ever have an engine rebuilt, check everything. One over looked rod bolt cost me into the thousands of dollars. I guess I'll have to chalk that up to experience. Later, FCG
I though that you pretty smart just a test.
Welcome to the.. " I Know My Stuff Club"
did you notice that 72 mario has a pic of your truck as his avatar fuelcellguy. i know you did
70 longbed 496/th400/Ford 9" |
FUEL CELL GURU
Yea...
I noticed the avatar. I don't know if I should be a member of that club but, what the hell. Later, FCG
Please !
I am just kidding around. I have got to change my avatar soon I think my truck is omost worthy. I just need to get My hands on a Digi Cam. Later Mario
chevelito
Hi,
Looking great. How did you tackle the problem of the a/c hitting the frame? are you going to cut it? jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
#13 |
FUEL CELL GURU
Frame...
I cut BOTH sides out. Check the pics.
#14 |
FUEL CELL GURU
Another...
it is kinda dark. I don't know if you can see the passenger side. It was pretty easy.
#15 |
FUEL CELL GURU
Home sweet home....
it's back in already. Here it is!
#16 |
Kewl...
#17 |
chevelito
I did a double take on your engine mounts...looks like you are using the stock LT1 towers.
Do I see an engine driven compressor for the bags...
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI Last edited by jay-dawg; 12-04-2003 at 12:30 AM. |
#18 |
FUEL CELL GURU
Mounts and misc....
The motor mounts are regular run of the mill Chevy mounts with the steel strap that is integrated to the mount. The steel strap keeps the engine from pulling up during acceleration in the event of a broken mount. The part number is DOAN 2283. I used 2" x 1/4" strap, welded to the frame in a triangulated fashion, for the frame mounts. Yes, that is a York compressor for the air ride. No more waiting.
