will a stock starter work?
will a new rebuilt stock starter turn 10:2:1 compression and a 168 tooth flywheel? or do i have to shell out the big bucks for gear reduction starter, only askin cause i cant di for the gear re starter at the moment and i need a new starter soon. thanks -kyle
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
It should. If it doesn't start, back the timing off just a little.
Formerly yellow72custom
I'm running a stock el-cheapo $30 starter on my 9.7:1 350 motor and it works OK....dosen't like to start when it is hot sometimes, but that is a header heat soak problem
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
its all about the +6 inches
Some engines came stock that way back in the day.
Don't expect the starter to last forever though. |
My other Love
Im running a stock starter onmy 12:1 454, cranks a bit slow, but it works and I have had it on there for two years so far
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Careful, they attack...
I had a stock starter on my 11:1 327 for 5 years and it started great. Never had a problem. Turned fine, started fine. Still have it, going to put it back on when I get done with the rebuild.
cool thanks -kyle
