09-07-2019, 05:29 PM | #1 |
1961 Front Wheel alignment
I’ve been doing some research and been only finding some information.
Can anyone show me what I need to do to adjust the front wheels. I got these two pictures. The passenger wheel in this picture is pretty accurate on the direction it is facing, noticeable pointing out to the right. While I am driving, the truck does want to steer towards the right and I am fighting the truck to keep straight sometimes. The driver side wheel is pretty straight but I can tell that it is pointing out a little. I marked center or straight on the steering wheel, turn the wheels all the way to the left, and I got 3 full and a 1/4 turns. Then I steered the wheel all the way to the right starting from the center pointing straight, and I only got a little under 3 full turns. Right now I have the wheels facing as straight as possible |
09-08-2019, 08:40 AM | #2 |
Re: 1961 Front Wheel alignment
Take it to an shop and have it aligned
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
09-08-2019, 09:42 AM | #3 |
Moderator
Are you asking how to adjust the toe-in/out?
09-08-2019, 02:48 PM | #4 |
09-08-2019, 02:50 PM | #5 |
09-08-2019, 04:08 PM | #6 |
Moderator
Loosen up the two end nuts, rotate the tube to move the front of the wheels in and out. There is one for each side, so...
