Old 12-02-2003, 11:32 PM   #1
Cheyenne Supr
Cheyenne Supr's Avatar
Question Power Steering Hose Connections
Hello,
I have a 72 Cheyenne 1/2 ton I am restoring (350 w/ TH400). The flare fitting on the power steering return line to the steering gear won't seal. I have a brand new OEM line with good threads. When the tubing nut is tightened all the way down to the last thread, there is still an 1/8" of play in the steel tube...the flare does not seat. From what I can view of the steering gear connection, it doesn't appear to have a flare fitting seat...it looks more like an o-ring seat. Does anybody know if some of the later model steering gears used an o-ring seal on the power steering hoses? The previous owner had many later model parts on this truck and I'm wondering if this may be a later model steering gear. There are a couple of casting numbers on the steering gear; 7802644 & 5686815. Any way to reference those to determine what years this gear was used in? Any other thoughts?
Thanks for your help,
Larry
Larry
72 Cheyenne LWB Fleetside Oak Bed 350 w/ TH400 (finally complete!).
69 Chevy C-10 LWB 350 w/ TH350 (good 'ol rusty bullet proof dependable hauler).
02 Suburban Z71 4x4 (wife's driver).
Cheyenne Supr is offline   Reply With Quote
Old 12-02-2003, 11:45 PM   #2
rage'nrat638
rage'nrat638's Avatar
does the female threaded part of the gear box have a taper seat?? inside...
sounds to me like the male threaded part of the hose don't go in far enough...if it's tight and the metal hose still is loose...
try a o-ring inside ...if it's the return side it's low pressure anyway
rage'nrat638 is offline   Reply With Quote
Old 12-02-2003, 11:47 PM   #3
rage'nrat638
o my 69 did have o-ringy dingy's
Old 12-02-2003, 11:50 PM   #4
cableguy0
a lot of gm power steering systems used the o-ring seal its a good possibility there should be one there and you dont have it in there
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-02-2003, 11:56 PM   #5
jhow66
jhow66's Avatar
Taper seats and o-ring seats are two different hoses. You have got the late model box. If you are using the early pump and late box you will have to change the pressue fitting in pump or take the new hose to a hose shop and have them put the right end on it.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-03-2003, 12:55 AM   #6
hgs_notes
GEARHEAD
hgs_notes's Avatar
I just had this happen to me. The 1977 and later boxes look identical, but they use O-ring fittings on the hoses. There was no adapter I could find, so I had to find another steering box or have custom hoses made. I went with the steering box for about $45 instead of odd ball hoses. Live and learn.
HG
hgs_notes is offline   Reply With Quote
Old 12-03-2003, 01:08 AM   #7
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
When I got mine the first one seemed to be missing a fitting, just a deep threaded hole. I took it back and had them pull a few more, same part #. Found one with a male fitting in place. Well, I needed a female fitting for my hose(male). I added a brass fitting (basically an extra long nut) which then made it a female fitting. Hasn't leaked a drop.
Confused yet?
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
Old 12-03-2003, 01:18 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Looks like you may have your answer...so let me be the first to welcome you to the board from Central Ohio.
Old 12-05-2003, 08:28 PM   #9
Cheyenne Supr
Cool
Thanks for the replies. After further investigation, I'm fairly certain this steering box takes the o-ring type of hose connections. Although I'm unable to positively identify the year of the gear, I did find a hydraulic hose shop who has ordered the correct fittings (we hope) and can make custom hoses for me. I'll let you know how it works out.
Thanks for the assistance!
Larry
Old 12-05-2003, 08:35 PM   #10
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-05-2003, 08:48 PM   #11
SEVEND2
SEVEND2's Avatar
Welcome to the Boards from Sunny So. Calif.
I had pretty close tot he same issue on mine, I had to change out the pump, to a new one, and then i got a good seal, It was a Bad pump on the one i got. Might want to check that
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 12-06-2003, 11:37 AM   #12
Cheyenne Supr
Thanks again for all the replies & welcomes.
Hey, SEVEND2, my old boss has a ranch in Wildomar....used to be called Lake Elsinore. Worked for him in Ontario, Calif.
We'll see how the 'custom' hoses work out.
Larry
Larry
Old 12-07-2003, 05:28 PM   #13
SEVEND2
SEVEND2's Avatar
The town next to me is Lake Elsinore, Wildomar has alot of Ranches... We like the open spaces!!!
and stage 2
Old 12-07-2003, 08:20 PM   #14
ABHaulR
ABHaulR's Avatar
on the back of the pump you can change the fitting type. the large hex base that the hose screws into can be taken out to change to the one you have. just go to a junk yard and take the one out that you need. clean it up and there you go. that way you dont have to go back to the parts house and go through thier inventory to find the right one. its not that bad.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
