09-10-2019, 03:17 PM | #1 |
3/4 ton Shear Type Cab Mounts
I recently got my cab mounts rebuilt by Steele Rubber Products in North Carolina. The quality of the rebuild is amazing. I thought I would post this thread for anyone who wants to keep their original shear type cab mounts. I would recommend getting a second set of cab mounts to have sent out to be rebuilt so you can still use your truck.
09-10-2019, 04:46 PM | #2 |
But Found Her 25yrs Later!
Re: 3/4 ton Shear Type Cab Mounts
What did they cost you?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-10-2019, 04:51 PM | #3 |
09-10-2019, 06:49 PM | #4 |
About how long did the whole process take? Was the cab height correct when installed? Looks good!
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
09-10-2019, 06:55 PM | #5 |
It was about 2 weeks. They said that it could be sooner or longer depending on how much work they have, but it's never over 3 weeks. I have not gotten around to installing them yet, but I'll be sure to update this thread with some pictures.
09-10-2019, 07:07 PM | #6 |
Did they come back to you re-painted black like that?
Any tips for removing the original cab mount rivets? I'm told they are a bear to drill out. Would love to hear how others have gotten them out cleanly without damaging the paint on the frame.
09-10-2019, 07:17 PM | #7 |
Yes, they came back exactly how they look in the pictures. I have used a nice sharp chisel on an air hammer in the past to remove rivets on some other frames, take the head right off and then you just need to punch it out with a punch bit. You just need to be careful how you aim the air hammer.
09-10-2019, 09:31 PM | #8 |
I grinded my heads off and then just punched them out.
09-12-2019, 03:50 PM | #9 |
What did you use for bolts when you re-installed? Did the rear cab height come out correct? I mean, did the body lines between the cab and box line up? Thanks.
12-11-2019, 03:59 PM | #10 |
Just wondering if you ever got your new cab mounts installed and how it came out.
12-11-2019, 04:13 PM | #11 |
I am dropping my frame off today to get powder coated. I will update this asap with installing the rebuilt mounts. Feel free to check out my build thread below, I'll post on there too about the mounts.
1965 C20 LWB Flatbed Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=795718 |
12-12-2019, 06:01 PM | #12 |
I'm wondering what size bolts others have used to bolt the cab mounts back to the frame. The original holes (which, obviously, contained rivets) are larger than 3/8" but smaller than 7/16" in diameter. Apparently not a standard size hole. What have others used for bolts?
