Cruise control accelerates then kicks off
Hey Guys
My 1997 C1500 when you push the accelerate button the engine rpm increases the stops Cruise goes off. When you try to set the speed sometimes works sometimes doesn’t any ideas easy fix or ???? Thanks for any info |
Re: Cruise control accelerates then kicks off
Could be the control box under the dash. I had some inconsistencies with mine and swapped it out with a junkyard box. Problem solved.
Mike |
Questionable
Really only two things I can see going wrong here, either the stalk/lever is sending bad info to the controller, or the controller box is bad. The lever can be a beast to replace on the 97-99 GMT400s. I would probably try to replace the controller box first. If you need it, I have a spare stalk I'd let go of at least 10-20% cheaper than anywhere else. It's not OEM, but it's made by Standard, which is (rumored to be) a manufacturer of some of GM's parts.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Could also be the brake swich. Thares two. One for the brake lights and one for the cruise.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
![]() Join Date: Sep 2002
Right, it might be just an adjustment that's needed. When the cruise is working see how much you have to push the brake pedal before it disengages. It might be right on the hairy edge.
| Bookmarks |
