![]() Join Date: Oct 2012
Radio light bulb
I was taking some parts/knobs off a stock 67-72 AM radio that doesn't work.
Removed the face plate and noticed the burned out light bulb. Saw that it's installed from the rear of the box, just pops right out. Never knew it was this easy to replace. Gonna buy a couple off Ebay to keep around, install a new one anytime I put a radio back in the dash. Bulb is # 1893.
Larry 84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles. 72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold) "It's a sorry man who can't find his wife a good job" |
Re: Radio light bulb
Thanks that helped me out. My bulb burnt out but did know the number.the radio don't work but the did light up
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I wonder if an LED would work in there. Would need one that didn't get too hot.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
LEDs don't get hot like that so no worries. The LED bulb number is BA9. I believe the BA9 works in the heater & a/c control panels as well.
72 C10 lwb fleetside -stock 350/350 combo |
Those look like they would fit.
I'd like to see one installed, how it looks at night, how the 'white light' looks and how bright it is.
![]() Join Date: Aug 2019
Hay 68 P.O.S. do they make a LED bulb to replace the inst. cluster bulbs?
Yes, they make 194 bulbs in LED as well
Dont buy the ebay/amazon leds. They don't last vary long and are poorly made. Spend the exta bit if you can. It will save you the headach latter on. Other wise just stay with stock.
#9 | |
https://www.amazon.ca/Yorkim-Bulb-Ca...omotive&sr=1-4
