Old 09-11-2019, 01:13 PM   #1
SeventyOne
Steering Column Bracket and Wire
Hey gang,
I have two questions as I reassemble my column/dash.
First are these brackets and the gap below the column correct? Seems off to me but I'm not sure how to correct it.
Second - the bundle of wires coming out of the column - there's 8 in the ribbon but i also have a tan/gray wire with a connector on the end. i *think* this goes on the back of the cluster but can anyone confirm?
SeventyOne is offline   Reply With Quote
Old 09-12-2019, 12:19 PM   #2
SeventyOne
Re: Steering Column Bracket and Wire
Nobody?
I did find this pic that seems to have the same gap, if not a little smaller.
Old 09-12-2019, 03:42 PM   #3
litebulblsc
litebulblsc's Avatar
My truck is a bit of a turd, but same gap.
litebulblsc is offline   Reply With Quote
Old 09-12-2019, 03:44 PM   #4
SeventyOne
thank you. thats 3/3 with the same gap. Unless someone says otherwise I'm gonna run it.
Old 09-12-2019, 05:23 PM   #5
simicrintz
Gap here as well; bone stock rig. Had to post-I hate odd numbers!
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 09-13-2019, 02:28 PM   #6
SeventyOne
To close the loop on my other question - the extra wire from the tilt column supplies power to the shift indicator. Non-tilts use the fiber optic cable.
On a normal wiring harness this would plug into the fuse panel. On my American Auto Wire harness I need to wire it into the cluster plug grey wire, doubled up with the stock grey dash lights wire.
Old 09-14-2019, 10:54 AM   #7
hemi43
hemi43's Avatar
I took that bracket right off on mine because it looked like crap right from the factory.
hemi43 is offline   Reply With Quote
Old 09-15-2019, 07:07 AM   #8
psuedopimp
psuedopimp's Avatar
Mine is off a 70 blazer. The fit is much better than yours is
Justin
1970 Blazer in progress
psuedopimp is offline   Reply With Quote
Old 09-15-2019, 12:42 PM   #9
SeventyOne
Interesting. And you have the U bolt in place holding the column to the dash?
Old 09-15-2019, 07:44 PM   #10
psuedopimp
psuedopimp's Avatar
Everything there is stock and not touched to my knowledge
Justin
Old 09-15-2019, 07:45 PM   #11
psuedopimp
psuedopimp's Avatar
If you look at post #3 it looks like the bracket used to be up and covering everything. Somewhere along the way it got pulled down
Justin
