09-11-2019, 11:52 PM | #1 |
Welding Aluminum Grille????
Has anyone ever tried to patch weld the aluminum grille’s?
I have 2 69’ grille’s, one has a good center section and the other has a great outer frame. It’s like if I could cut and re-weld the 2, I’d have 1 really nice grille.
1965 c/10 swb 1969 c/10 lwb |
09-12-2019, 08:29 AM | #2 |
Re: Welding Aluminum Grille????
That is really specialized welding because you have to deal with the anodized coating on the grill , I have mutiple welding certifications but never welded anodized aluminum .but heard that its not easy and I dont think you could hide the welds without painting the whole grill to match or removing the hard anodized coating off the entire grill.
09-12-2019, 10:15 AM | #3 | |
09-12-2019, 01:23 PM | #4 |
I would be looking into playing around with some solder. Maybe try some Muggyweld super alloy 5 for aluminum rod and flux.
j
White K20 |
09-15-2019, 06:36 AM | #5 |
The anodizing will cause problems as you know.
But... remove the anodizing layer, back it, and run a bead. Then sand the bead off and polish the grill or re-anodize. However if you decide to re-anodize remember that 5356 rod should be used over 4043 because the 4043 will turn black under anodizing. I prefer 4043 because it flows better. I haven't tried it yet but i have thought about it since the 69 grills are a little different.
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
