09-12-2019, 05:55 PM | #1 |
Stock Seat Riser
The seat riser in my 47 (2) is pretty rusted and has been modified. Is there anywhere to get another, or do I need to fab something up. This is for the stock AD seat.....
09-12-2019, 06:08 PM | #2 |
Re: Stock Seat Riser
Unless you know someone removing the stock riser or anyone cutting up a cab, I don't think there's an aftermarket replacement.
My dad had taken mine out in the 70's for bucket seats. I had to take a spot weld cutter and chisel to another cab that was being parted out.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
09-13-2019, 04:29 AM | #3 |
It's very common for the S10 conversion guys to use those mid-90s C10 seats. I'll bet if you asked on the S10 Swap forum many of them would have their original seat riser laying around.
1951 Chevy Panel Truck |
09-13-2019, 07:47 PM | #4 |
They are a bear to take out though.As Jweb said spot weld cutter and chisel. I've got some that would be free if you took one out but real expensive if I did it.
09-13-2019, 08:10 PM | #5 |
I ran an air chisel under mine - came out surprisingly easy.
09-14-2019, 12:18 AM | #6 |
So did I but it didn't look too pretty. The one in my cowl donor cab would be a simple one as I have to take it out to cut across the floor anyhow. Trouble is it is buried in the shed I need to tear down.
09-14-2019, 08:30 PM | #7 |
I have a stock seat riser from my old '46 that I found because it didn't have one. The flange on it is a little chewed up - probably from someone else using an air chisel on it.
Too bad you're as far away as you are.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
