Trick for installing park brake cables?
Hey all,
I upgraded my brakes all around, and just got new park brake cables for my rears. Problem is, despite them connecting to the same point on the trailing arms, it feels like the overall cable is about 2" too short to reconnect. Even after removing the cable from the adjuster rod on the driver's side near the transmission, it's simply too short for me to hook up the brake cable to the driver side disc hat, and still get the cable back into the adjuster rod. If I put it into the adjuster rod again, then I can't physically get it close enough to the trailing arm bracket to hook it up. Not sure what the hell to do lol. Anyone run into this? |
![]() Join Date: Aug 2010
Re: Trick for installing park brake cables?
I had the same problem, solved it by adding a 3" piece of threaded rod and a threaded coupling to give me additional length for adjustment. That was my fix, anyone else have to deal with this?
Post Whore
![]() Join Date: Feb 2016
Is the hook on the front passenger side in the correct hole? I am assuming the rear cables are the same length as the old ones.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
