![]() Join Date: Aug 2017
Speedo Help - Yes I've searched :)
So after searching through 433 results I still don't have an answer...
So I have a 65 C10, 327, and 3 on the tree. Last winter I complete redid an all gauges cluster and swapped it out for my lights cluster. In the process, I also replaced the speedo cable and it has a brand new speedo in it from LMC. So ever since the install, the odometer works perfectly, but the speedo bounces slightly and once I reach 50mph the speedo will stick and not move again until I shut off the truck. Thoughts? Bad cable? Or bad gear in the transmission? I have another gear from a parts 3 speed that I'm going to swap over next weekend but wanted to get your thoughts? |
![]() Join Date: Feb 2014
Re: Speedo Help - Yes I've searched :)
Send it back to LMC if it sticks it’s the problem
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
If you have visually inspected the gear and cable along with the ends and all moving components and found nothing. You might try some sort of lubricant sparingly on the cable.
Posted via Mobile Device |
Well, I've contacted LMC and they are sending me a replacement cluster. I hate to have to pull all of this out but hopefully that's it. I've checked the cable and its not binding at all. I've not lubricated it, but I will try that.
I will keep everyone posted. |
Vaseline Works, if you can hook the new one up and try it before installing
![]() Join Date: Oct 2006
x2
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
![]() Join Date: Aug 2019
Buy speedo cable lubricant. Use the right stuff.
