Old 09-19-2019, 05:30 PM   #1
Dachshund
Modern Tie Rod
What is a good source for the modern tie rod/ends for and AD? Also, is there an after market pitman arm and drag link? Or is that a "mod"? Thanks! I'm ready to order, and I need to know where from!
Dachshund is offline   Reply With Quote
Old 09-19-2019, 09:10 PM   #2
mr48chev
mr48chev's Avatar
Re: Modern Tie Rod
The drag link is the easy part.
The filling station shows the tierod with ends and that means some of the others will have it too. https://www.parts123.com/parts123/yb...5Z5Z50000014x#
53 and 54 used a drag link with the "modern" ends on them That can be had through Rock auto https://www.rockauto.com/en/catalog/...nter+link,7276 or pay twice that from a truck trinket vendor. You would have to have your pitman and steering arm taper reamed for the ends or replace them with the pieces off a 53/54.
Chevs of the 40's sells the same drag link for 103.00 https://www.chevsofthe40s.com/detail..._Rod_Ends.html
My ongoing truck projects:
Old 09-20-2019, 09:18 AM   #3
nvrdone
Re: Modern Tie Rod
I had a local 4x4 shop build mine. I needed the eyes in the spindle arms re tapered because the tie rod now mounts under the arms instead of above due to a dropped axle. they did a great job.
nvrdone is offline   Reply With Quote
Old 09-20-2019, 09:30 AM   #4
MARTINSR
MARTINSR's Avatar
Re: Modern Tie Rod
Yeah, I had Sids do my tie rod and drag link. https://droppedaxles.com/
I am not thrilled with the tie rod, it's a bit "thin" for my liking but they have sold many and people all over are happy with it so I am going with it.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 09-27-2019, 04:18 PM   #5
Dachshund
Re: Modern Tie Rod
SOOOOO....if I get everything from a 1954 - including the pitman - it will all just bolt up?
