Old 09-19-2019, 05:44 PM   #1
brodon
brodon's Avatar
Door hinge problem that appears to be unusual.
The threaded "plate" behind the opening of the door hinge with the holes/threads that secures/treads the bolt, came loose and has dropped to the bottom, inside the door with no way to get to it. i.e. nothing to tighten the door hinge to on the cab.
It's in private storage to I don't have access to a welder.
Evidently no one has experienced this before, since I've spoken to several auto body folks with no idea of what to do.
Would anyone have something I can try to get my drivers side door on my '67 so I can proceed from there.
Thank you,
Don
brodon is offline   Reply With Quote
Old 09-19-2019, 06:00 PM   #2
truckster
truckster's Avatar
Re: Door hinge problem that appears to be unusual.
If you want something temporary you could try well nuts.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-19-2019, 07:00 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
If the piece has dropped into the door, you can retrieve it by removing the door panel and fishing it out...see pic for what it looks like....
If the piece you mention is inside the pillar you can make up a new threaded section and cut a slot in the pillar to replace it....drill some small holes in the outer skin of the pillar and tack weld it in place....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 09-20-2019, 06:40 PM   #4
68 TT
Still plays with trucks
68 TT's Avatar
All that holds it to the door shell when the hinges are not bolted to it are those small spot welds. Sounds like yours broke loose from the shell. You should be able to get it in place from inside the door and use the hinge bolts to lock it down.
You should be able to feel where the spot welds held it in place and locate it appropriately. Run the bolts down to clamp it tight then install a couple flat head crews or rivets to lock it down there. You should be able to put the hinge back on after that. Once the bolts are torqued down they won't let it move around.
When you get it home you can weld the plate to the door if you feel you need to.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-20-2019, 08:58 PM   #5
BigBird05
If you need to replace the plate let me know I have a scrap door or I can get a plate for the A piller from a donor that I know of.
BigBird05 is offline   Reply With Quote
Old 11-29-2019, 10:35 PM   #6
1mrtimk
Did you ever retrieve the backing plate?
1mrtimk is offline   Reply With Quote
Old 11-29-2019, 11:29 PM   #7
HO455
Post Whore
HO455's Avatar
There are several threads out there about this problem. So don't feel too bad you are not alone. Do a search using the box above.
Here is one thread from a search. Scroll down and you can see what they did to fix the problem. It also shows the where your missing plate is likely to be found.
Good luck
http://67-72chevytrucks.com/vboard/s...=438045&page=5
RIP Bob Parks.
door hinge, door hinge plate
