Old 09-19-2019, 10:22 PM   #1
JHILDE
JHILDE's Avatar
Shock relocation (not extenders)
Has anyone relocated the rear shocks to get a better angle/more vertical? Thinking of moving them both to the back of the axle.
2wd, flipped rear with assassin traction bars.
JHILDE is offline   Reply With Quote
Old 09-19-2019, 10:33 PM   #2
sweetk30
sweetk30's Avatar
Re: Shock relocation (not extenders)
2wd or 4wd ?
lifted or lowered ?
the reason there staggered 1 front / back is to help control axle wrap a little from the factory from what i have read over the years .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-19-2019, 10:58 PM   #3
JHILDE
JHILDE's Avatar
Originally Posted by sweetk30 View Post
2wd or 4wd ?
lifted or lowered ?
I went back and added more info. 2wd, flipped, assassin traction bars.
Old 09-20-2019, 11:14 AM   #4
SCOTI
SCOTI's Avatar
I did for my dually but I also ditched the leaf packs for a 4-bar w/rolling sleeved bags using the OE housing spring pad locations for the brackets everything attaches to. Both shocks are now mounted just behind the rear end.
it's not a bad idea for your flipped set-up (def better vs. the exaggerated angle the relocation brackets put the shocks at).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-20-2019, 02:20 PM   #5
JHILDE
JHILDE's Avatar
I thought about a 4 link but this truck is just going to be a hot rod cruiser, it was my granddad's and I don't want to cut it up a bunch. I have another truck planned and will probably be a built chassis, caged, and full stupid.
Old 09-20-2019, 03:36 PM   #6
SCOTI
SCOTI's Avatar
Mine was swapped strictly for ride quality & adjustment when pulling a trailer. C10's (c20's & c30's as well) ride so much better w/o the leaf set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-20-2019, 06:17 PM   #7
JHILDE
JHILDE's Avatar
I know me and I'll prob just 4 link and coilover it later.
Old 09-21-2019, 11:11 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
How I did mine.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
