Old 09-20-2019, 09:07 AM   #1
CHEVYRULS
Smile 67-72 Short Bed Conversion
i am in the process of cutting a long bed frame down to a short bed. WhY well the 67 frame with coil overs which has been sitting in this guys lot for 20yrs (With NO BODY) i bought it to make a Short bed truck. i have a cab from a 72 and i purchased a short bed from LMC.
what i want to know is the measurements from the front of the frame to the rear so i can be sure to weld this sucker to the correct length when i put the cab on.
I have the diagram which has various measurements mixed together, which is some what confusing.
what about a measurement from the radiator mount to the rear bed mount or to the center support brace?
Remember I don't have the original BODY parts that was originally on the frame. So Don't bash me about leaving it a long bed.
I did follow the step Cut video that STACY DAVID , season 7 episode 3. I watched it a number of times. Double checking my measurements. At this point The frame has been cut .
Once I figure out how to display pics I will show where I’m at
V/R
James
CHEVYRULS is offline   Reply With Quote
Old 09-20-2019, 09:34 AM   #2
MDPotter
MDPotter's Avatar
Re: 67-72 Short Bed Conversion
You should be able to look up the frame dimensions on the internet, or within this forum. There are diagrams by GM which have several dimensions from several reference points on the frame. If I were you, I would cut 12" out of the middle and 6" off the back. No need to worry about attaining a certain overall dimension unless you think it's been modified previously. Just make precise cuts by leaving about 1/8" extra and then sneak up on the line with a grinder and test fit until it looks perfect. I made some reference marks before I cut mine to be safe. Also check it diagonally before you weld it in to make sure it's straight.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 09-20-2019, 09:36 AM   #3
Astro-Balls
Astro-Balls's Avatar
Did you buy the kit?
https://www.youtube.com/watch?v=ZK30C3yWvA4
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 09-20-2019, 09:54 AM   #4
randy500
Cut exactly 12” out of the frame between the cab mounts. I scribe lines 12” apart to cut and 16” apart to verify the final length...those 16” lines will now be 4” apart. Or do some other combination if using a Z cut, which you should. I lay that out on paper and transfer to the frame. Usually 6” offset.
Avoid cutting the vin stamped in the drivers top frame rail and avoid any bends in the lower frame rails, usually only on later model fames.
Move the cab mounts back exactly 12”, scribe lines again, and scribe lines for the cab mount height or make a height jig from wood.
I think the rear cut is 7 7/8”...verify by measuring the distance between the 2 sets of bumper mount holes in the rear frame horns, cut the same amount off as the distance between the bumper mount holes.
Cut and re- flare the rear brake line, make the cut at the front.
Use a dorman cable stop to shorten the emergency brake cable.
randy500 is offline   Reply With Quote
Old 09-20-2019, 10:01 AM   #5
MDPotter
MDPotter's Avatar
randy500 is right, it is 8" off the back. You can z-cut for the most strength, or do an angled cut like I did. Either way, weld in a plate on the inside for strength. I used the piece that I cut out for that plate.
Here's a link to a frame shortening thread: https://67-72chevytrucks.com/vboard/...d.php?t=123624
Old 09-20-2019, 10:18 AM   #6
CHEVYRULS
No I didn’t buy a kit
Old 09-20-2019, 10:20 AM   #7
CHEVYRULS
This frame is stripped, the cross member on the front and the axel in the rear has been stripped. Just the frame is there. I’m looking at replacing the complete front suspension
Old 09-20-2019, 01:18 PM   #8
CHEVYRULS
Originally Posted by Astro-Balls View Post
NO KIT, I prefer the step cut, plus I will enclose the frame where it was cut.
Old 09-20-2019, 01:34 PM   #9
CHEVYRULS
Thanks that will help
Old 09-20-2019, 03:01 PM   #10
Myself
Very detailed thread on shortening, this is the method I will be using.
http://67-72chevytrucks.com/vboard/s...d.php?t=667694
Myself is offline   Reply With Quote
Old 09-20-2019, 03:24 PM   #11
randy500
You can also verify the end frame cut by measuring the distance between the last 2 bed bolt holes on a long bed and a short bed. I come up with 7 7/8”
Here is the cable stops for shortening the e brake cable, you have to drill the hole out to the proper size but they hold very tight and fit in the metal front to rear cable connector real nice.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 09-20-2019, 04:59 PM   #12
CHEVYRULS
i did not buy the kit
i watched Stacy David do a frame, I prefer the Step Cut.
frame measurements, short bed conversion
