Old 12-03-2003, 04:08 AM   #1
jorgensensc
jorgensensc's Avatar
How hard is it to polish things???
I'm hoping to get a dremel ths xmas and would like to polish some engine stuff. How hard is it and what do you use for chemicals and polish? Any suggestions would be great too!!!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-03-2003, 04:12 AM   #2
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
jorgen, what kind of dremel are you looking to get? i want to get a dremel as well to clean and polish things on my truck. do they make attachments that are specifically made for polishing stuff?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 12-03-2003, 04:29 AM   #3
jorgensensc
I figured you would post smokin!! I was reading your other post.
I want to get this:
Dremel
Not sure how good it is though.
Old 12-03-2003, 05:31 AM   #4
67cst
i love summertime
67cst's Avatar
if either of you guys are interested i got a brand new dremel, still in the box, its the deluxe setup with all sorts of add ons and lots of extra discs and buffing bits...pm if your interested
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 12-03-2003, 05:45 AM   #5
jorgensensc
I PMed you.
Old 12-03-2003, 07:18 AM   #6
Terry Peerson
I wanted a Dremel-Tool for years..until I got one. IMO it is the most useless tool that I own (and I own some useless tools!) It is too light-duty to do much of anything other than maybe carve your name in a SOFT piece of wood. I bought it when I was doing some ceramic-tile work in the kitchen. I thought it would be handy to make the more complicated cuts. I was WRONG!
Just my 2-cents
Terry Peerson is offline   Reply With Quote
Old 12-03-2003, 11:10 AM   #7
tom hand
CCRider
tom hand's Avatar
I agree with Terry Peerson...A Dremel is tooo light duty to do much polishing. To do any real polishing, you need at least a buffing wheel on a bench grinder, and a die grinder for nooks and crannies. Eastwood has all the stuff you need to do it, and even a "how to" video.
http://www.eastwoodco.com/department...bCat=Compounds
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-03-2003, 12:12 PM   #8
sactoC10
71 DELUX
sactoC10's Avatar
Ditto on the dremel. Polishing takes practice, and much trial and error. I do not have a bench grinder, so in place of my Dremel which was not effective in my attempts to polish, I started using buff and polish attachments on my drill. I have polished numerous motorcyle parts this way (frame, wheels, forks, etc...). Not sure what parts you intend to polish, but I found wet sanding to be the "secret ingredient" in the successful polishing recipe. That and patience. Read all article, such as the Eastwood one...and practice. Also note that different metals will require some different techniques.
sactoC10 is offline   Reply With Quote
Old 12-03-2003, 12:28 PM   #9
cdowns
cdowns's Avatar
with a dremal you could polish nuts and bolts that's about it
Old 12-03-2003, 12:43 PM   #10
RON WOODGEARD
Resident Young Old Dude !
The dremel is TOO SMALL for "most" jobs, It is great for getting into tight small areas, but don't plan on polishing valve covers or an intake.... The wheels are too small, and you will polish ridges, pockets, or rough spots into what you're working on.
You need a bench grinder/buffer. speed of about 3500 RPM. 1/2 horse or more motor. I have one that I use for my jewelry work, and An old jewelry one that I use for my Toy work.
A good drill will work with attachments, But be prepared to burn it up, or waste the bearings, A drill is designed to drive it's force straight down, not take the pressure from the side. ( been there, Done that!) I used a drill on my grille when I reworked it for the Billet insert. I posted pictures of it step by step. a year or so ago. Also posted pictures of an Old set of M/T valve covers I revived. the dremel will work in between the fins, kinda...
You start with a aggressive cutting compound and a 4" to a 6" Buff wheel, then you work your way down in aggressiveness until you are very smooth compound and a very soft, Cotton, or Muslim Buffing wheel.with a very smooth rouge, compound. It works just like sanding, rough to smooth.
Been doing this stuff as a profession for 24 years.
RON WOODGEARD is offline   Reply With Quote
Old 12-03-2003, 02:34 PM   #11
sactoC10
71 DELUX
sactoC10's Avatar
Yes, you will burn up the drill. I go through drills often, but they are failrly cheap ones that I buy, knowing that I will eventually fry the bearings. But they do work good, especially when you have parts that would be hard to hold up near the bench grinder/buffer.
Old 12-03-2003, 04:01 PM   #12
jorgensensc
Wow!! Thanks for all of the great information!!! I guess I won't be getting one!!! I was hoping it would be good for polishing and doing other type work, but I guess not!!! Thanks again!!!
Old 12-03-2003, 04:22 PM   #13
dtlilly
dtlilly's Avatar
I'm surprised Dinnut hasn't responded here, he has "love to polish things" under his avatar. I agree the dremmel is light duty. I used one to etch my name on all my tools.
dtlilly is offline   Reply With Quote
Old 12-03-2003, 06:54 PM   #14
Hutch
Hutch's Avatar
This would look good in a Chevy truck.
You might have to wear shades when you opened the hood though.
Deals on Wheels
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 12-03-2003, 07:03 PM   #15
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
I am not to fond of dremmels either. They are okay with the little cut off wheels on them.
I just did a quickie polish on an intake. I used a 6 inch sewn buffing wheel(white & tripoli compounds) mounted on a drill press. Used an 8 inch piece of 3/8 all-thread to chuck it up. Gave great access to the wheel this way.
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
Old 12-03-2003, 11:14 PM   #16
dinnut
dinnut's Avatar
i just saw this post i love to polish things and also wan a dremel or something like it for christmas so i actually polish things
heres what i got for my birthday... my first polishing tool will also be used to sand rust away...
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
