09-20-2019, 06:31 PM | #1 |
Brake return spring
This can apply to about any year of truck, but having a 56 I wanted to stay with this forum. I have my MC mounted to the firewall so my brake pedal goes thru it, and have been noticing my brake pedal lagging some on return so I need to mount a return spring, do you have pictures of how you did it and mounted the spring to what part of the brake arm to what did you mount the spring to?? Pictures would be appreciated if you have them. Thanks
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
09-20-2019, 11:44 PM | #2 |
Re: Brake return spring
I used a dishwasher door spring I had laying around - about 7" long, with hooks on both ends. I drilled a hole in the pedal arm and hooked the opposite end to a factory hole in the underside of the dash. Mostly hidden unless you look under the dash. Sorry, but you'll have to pay me $20 to crawl under there and take a photo
1951 Chevy Panel Truck Last edited by MiraclePieCo; 09-21-2019 at 05:23 AM. |
09-21-2019, 11:59 PM | #3 |
Dang, you never give that much thought until you have the need for one.
I'd have to say it might depend on how much effort you want to put into installing a spring that will get the job done. I don't know what those springs are called that work like one of those spring hand grip things that guys use to strengthen their grip but that style might work if you can put it around the shaft that the pedal rides on. a coil spring like Miricalpieco used is probably the simplest. Flat lazy is a shotr bungie cord.
09-24-2019, 12:15 AM | #4 |
Maybe something like this since you are using swing pedals.
https://www.ebay.com/itm/55-56-57-Ch...UAAOSwVJVcu-wv Mine is under the floor and I had to put in a helper string to get my lazy pedal to come completely up. John
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch. |
09-24-2019, 04:51 AM | #5 |
before doing too much spring work, maybe disconnect the pushrod to the master cyl and make sure the pedal is free moving. sometimes things can get pretty stiff or even bent and we get used to it slowly so don't think about it. if it used to work fine then check the pivot point bushings by doing the above. the pedal should be free and easy. if it does and a spring is all that's needed try using a longer pin through the pushrod and drill an extra hole in it that will accept a pull type coil spring, like the screen door springs available at the hardware stores. slip a piece of light rubber tubing over it, like from a kids bike tire, and that will stop the spring from making noise as it gets pulled. connect the other end of the spring to something sturdy and/or make a bracket for it that places the spring in the right geometry to pull straight back from the pushrod so it can work well. I have also seen the pedal length extended on the opposite side of the pivot and a heavy coil spring used in that short distance between the firewall and the pedal arm. the shorter the distance from the pivot the heavier the spring needs to be so it can offset the weight of the pedal.
10-01-2019, 06:33 PM | #6 | |
10-01-2019, 08:21 PM | #7 |
also install a rubber bumper for a pedal stop so you aren't pulling the plunger out of the booster. the booster has a return spring inside so it should be coming back all the way unless it is faulty. if your pedal is returned with a spring and it is not set up properly with a stopper then it could cause some issues. I would say drop the pedal pin to the pushrod, ensure the pedal is swinging freely for the whole stroke and the booster is also returning properly, then install the pedal pin and a rubber pedal stopper so the pedal has an end point to it's return stroke. if it ends up in the wrong height for your foot then adjust the pushrod travel and the bump stop accordingly.
10-04-2019, 11:58 PM | #8 | |
10-05-2019, 12:01 AM | #9 | |
10-05-2019, 05:07 PM | #10 | |
Do you have a mechanical brake light switch? It could be holding off the pedal.
1951 Chevy Panel Truck |
