A/C line size issue. '77 C30 6.0
New parallel flow condenser has a #8 inlet and a #6 outlet. Factory evaporator line where the orifice tube is appears to be #8. How do I transition sizes?
Recommended driers? Stock replacement? My condenser came with a drier and binary switch. I'm planning to add the GM transducer switch/sensor in the compressor discharge line. |
Re: A/C line size issue. '77 C30 6.0
you can get a #6 fitting for a #8 line.
https://coldhose.com/fittings/oring/female-oring.html
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#3 | |
BMW & ASE Master Certified
Sure the inlets a 8, and outlet is a 6?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
