Old 09-21-2019, 08:16 PM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up GM Home link garage door opener
As the title states, GM 3 button home link garage door opener.
I just finished installing another one in my 67 Ramp truck.
Very simple to install and it will work up to 3 doors. 12v hot & a ground wire is all you need. I have them in the 71 C 10, Ramp truck and the 64 SS Impala.
You program it just like the manual in your GM car. Are do as I did look it up on the net.
Anyway here is a short video of the Ramp truck install I just finished. I cut the visor so it would sit better and it's a rat truck so it doesn't matter. I may later have it covered though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-22-2019, 11:23 PM   #2
El Dorado Jim
Re: GM Home link garage door opener
very cool
El Dorado Jim is offline   Reply With Quote
Old 09-23-2019, 08:52 AM   #3
72LB
72LB's Avatar
Andy what year vehicle did you get them from?
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 09-23-2019, 07:21 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: GM Home link garage door opener
2000 and up Tahoe are GM car. Just look for them and the panel piece that comes off with them.
Old 09-24-2019, 07:35 AM   #5
72LB
72LB's Avatar
Ok thanks, I'll put that on my list for the next LKQ trip.
Old 09-24-2019, 09:51 PM   #6
Andy4639
Old member
Andy4639's Avatar
Look for one pictured in the 67Ramp truck. It seems to be the easiest to use.I have the same one in my 71 inside the Ash tray and it works ok inside it. I cut it up before I realized it would fit.
I cut the visor up on the ramp truck to mount it.
Old 09-25-2019, 04:09 PM   #7
72LB
72LB's Avatar
Ok thanks.
Old 09-25-2019, 07:30 PM   #8
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Cool Andy!!!
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 02-17-2020, 10:56 PM   #9
Andy4639
Old member
Andy4639's Avatar
Update on this cool mod and the mirror mod I did a while back! I have had both now for a couple of years and this will knock out to mods in one.
First 2 pictures are what I bought tonight.
The one I have now works but the range isn't that great since it's inside the ash tray. I bought this out of a Tahoe. I didn't know at the time they had them in mirrors in other makes.
Tonight I found a new mirror that has the Compass, Temp-Green Display and the home link 3 button in it. I will be swapping the mirror out once I get it. This should make the door opening much better.
With it being in the mirror it will double the range I hope.
