Old 09-22-2019, 10:10 PM   #1
AirSpeed
AirSpeed's Avatar
Odd holes drilled in edlbrock aluminum intake
A friend gave me an edlbrock intake manifold a while back, I was looking at it today and noticed two holes drilled in it, one about 3/8” and the other about 1/4”. I can see them looking down through the carb mount. They don’t look factory as one has slag on the edge from drilling. Any idea why someone would drill these holes? I’ll take a pic tomorrow when I go to my shop.
AirSpeed is offline   Reply With Quote
Old 09-22-2019, 10:14 PM   #2
hjewell2
hjewell2's Avatar
Re: Odd holes drilled in edlbrock aluminum intake
Extra Vac ports?
hjewell2 is offline   Reply With Quote
Old 09-22-2019, 10:17 PM   #3
AirSpeed
AirSpeed's Avatar
Originally Posted by hjewell2 View Post
Extra Vac ports?
They’re inside the manifold, they would be right under the carb if it were mounted
Old 09-22-2019, 10:21 PM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: Odd holes drilled in edlbrock aluminum intake
Nitrous nozzels maybe!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-22-2019, 10:26 PM   #5
AirSpeed
AirSpeed's Avatar
Right inside below the carb, not sure what the intake of an intake is called! . Pic is for reference
Old 09-22-2019, 10:28 PM   #6
Warrens69GMC
Warrens69GMC's Avatar
Egr crossover, to reduce emissions
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-22-2019, 10:30 PM   #7
AirSpeed
AirSpeed's Avatar
Could they be stock? They are both on one side and seem to drilled in a random fashion.
Old 09-22-2019, 10:32 PM   #8
Warrens69GMC
Probably not factory
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-22-2019, 10:35 PM   #9
AirSpeed
AirSpeed's Avatar
I’m thinking of filling them with some aluminum rod, will it make a difference, I don’t have to ever smog it, building a backup engine for my boat
Old 09-22-2019, 10:37 PM   #10
geezer#99
geezer#99's Avatar
Like this.
https://www.peerhub.com/items/8850-e...-car---working
Area under the carb is the plenum.
Old 09-22-2019, 10:38 PM   #11
AirSpeed
AirSpeed's Avatar
Originally Posted by geezer#99 View Post
Like this.
Yes, but the holes are on one side and two sizes
Old 09-22-2019, 10:53 PM   #12
geezer#99
geezer#99's Avatar
Is the intake a single plane like your reference pic or a dual plane like my link shows?
That could be the difference.
Old 09-22-2019, 11:32 PM   #13
Warrens69GMC
After thinking about it, is the 1/4" one slightly forward of the 3/8"?
If the 3/8" is being used for egr function, the 1/4" would be used for PCV if being used with valve covers without a pcv
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-23-2019, 07:23 AM   #14
BigBird05
Tap them and use lock tite.
BigBird05 is offline   Reply With Quote
Old 09-23-2019, 08:26 AM   #15
68Gold/white
I'm still clueless on what holes you are talking about...............
68Gold/white is offline   Reply With Quote
Old 09-23-2019, 01:33 PM   #16
AirSpeed
AirSpeed's Avatar
I was wrong, the holes are on either side. It is a dual plane intake. Should I bother plugging them or just leave them alone?
Old 09-23-2019, 01:41 PM   #17
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Good to know I'm not the only one! Apparently there are no such holes in the reference pic, which is what I was looking at.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 09-23-2019, 01:43 PM   #18
geezer#99
geezer#99's Avatar
I’d drill them both the same size, tap them and put plugs in. Then jb weld to seal them.
That way you know you want have any leaks.
Old 09-23-2019, 01:43 PM   #19
AirSpeed
AirSpeed's Avatar
Originally Posted by Stocker View Post
Good to know I'm not the only one! For the life of me I cannot see the holes in question....
Geezer posted a link to a pic, mine is just like the pic. Don’t know why I was thinking the holes were on one side, might have been the beer I drank after work!
Old 09-23-2019, 06:54 PM   #20
AussieinNC
Moderator
AussieinNC's Avatar
Sounds like a cheater NOS nozzle installation....one for NOS, one for fuel....
They hide the nozzles inside the manifold....
Post a pic of the manifold...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 09-23-2019, 08:19 PM   #21
Bigdav160
Bigdav160's Avatar
Look like EGR passages to me
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-24-2019, 05:37 PM   #22
rcazwillis
Looks like a modification for the choke coil. Maybe?
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 09-24-2019, 08:33 PM   #23
AussieinNC
Moderator
AussieinNC's Avatar
EGR feed ports...
Ones in plenum, just tap them and plug them up.
Put metal cover over EGR exterior port...
Block off choke heat riser port if you are using an electric choke carb...
2012 Chevy Equinox
