Old 09-24-2019, 12:28 AM   #1
Dodge68charger
Radiator Support Question?
Will A 67-68 Radiator Support Work On a 69 C10
I Thought They Were All The Same n BodyWorked Mine Only To Find Out They Are Different
Anything I Can Do To Make It Work? I Know Where Theres a 69 Support But Too Far On The 68 And Will Modify To Make It Work
Dodge68charger is offline   Reply With Quote
Old 09-24-2019, 07:03 AM   #2
66clow
66clow's Avatar
Re: Radiator Support Question?
Yes but you have to change all the sheet metal to 67-68 to match.
66clow is offline   Reply With Quote
Old 09-24-2019, 09:57 AM   #3
Dodge68charger
The Sheet Metals Already Painted.
Guess I’m Out Of Luck and Have To Use a 69 Support.
Damn
Old 09-24-2019, 10:20 AM   #4
66clow
66clow's Avatar
Damn
Yes I'm sorry the joy and pain of customizing and restoration. Should be easy to sell the support tho. 69-72 will work if you find one.
Old 09-24-2019, 12:00 PM   #5
Dodge68charger
Thank You
Old 09-24-2019, 10:46 PM   #6
randy500
The 68 will work fine, you need to install the headlight buckets from a 69-72 core support, to get them in the right spot, i install the grill and center the headlight in the bezel, then tack weld, remove grill for final welding.
randy500 is offline   Reply With Quote
Old 09-24-2019, 10:47 PM   #7
randy500
Im almost sure i have a set of headlight brackets i could sell you if you need a set.
Old 09-25-2019, 02:26 AM   #8
Dodge68charger
Thanks Guys. I Should Have a Spare Set Of Brackets On My Rusty 69 Support I Can Use. As Long As Thats The Only Difference I’ll Drill Out The Spot Welds This Week
Appreciate The Help
