Old 09-28-2019, 02:33 PM   #1
Mryan
Active Member
Door Advice please
So I find myself needing a passenger door for my 71. Opinions please on finding a OEM door or buying a new aftermarket door. If aftermarket what is the favorite supplier or brand?
Mryan is offline   Reply With Quote
Old 09-28-2019, 03:41 PM   #2
truckster
truckster's Avatar
Re: Door Advice please
If you can find a decent original door I would definitely go with that. You'll have far fewer issues with fitment.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-28-2019, 08:30 PM   #3
2 Stovebolts
I second that.....
2 Stovebolts is offline   Reply With Quote
Old 09-28-2019, 08:38 PM   #4
Grumpy old man
Grumpy old man's Avatar
I just bought a set of doors in decent condition with internals for $40.00 locally , If you can find a passenger door in nice shape for $250.00 buy it !
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 09-28-2019, 10:43 PM   #5
flashed
Just be glad you dont need a good 72 door , they seem harder to find . I tend to hoard those when I find them .
flashed is offline   Reply With Quote
Old 09-29-2019, 07:57 AM   #6
66clow
66clow's Avatar
Not sure how to delete my post. Somehow got to the wrong thread.
66clow is offline   Reply With Quote
Old 09-29-2019, 08:07 AM   #7
2 Stovebolts
Aren't all doors interchangeable from 67-72???
Old 09-29-2019, 09:13 AM   #8
LagunaGlide
This was going to be my question as well. I know I will be needing to replace my drivers door at the very least.
LagunaGlide is offline   Reply With Quote
Old 09-29-2019, 10:09 AM   #9
flashed
72 doors are different , inner door parts are different to work with the plastic door panels , but yes they will all fit . 67/8 I believe the outside door handle is different but again will fit .Good doors are still out there but hard to find in my area .
Old 09-29-2019, 10:20 AM   #10
2 Stovebolts
So I guess at a quick glance you can tell the difference between the flat metal inner door panel vs the molded plastic one.....and trying to make the interior door panels interchange with each other?.....However all doors will bolt on & fit...
Old 09-29-2019, 10:33 AM   #11
flashed
Yes , you got it .
