Old 09-28-2019, 03:31 PM   #1
randy500
Tilt column, column shift auto, serviced and painted.
This is a motorhome conversion column and its a direct bolt in, no modifications needed.
Motorhome columns have a stepped shifter arm which does not effect shift linkage operation.
Motorhome columns have the correct short stick-out splined end so no need for modification of your intermediate steering shaft.
To make it a direct bolt in I moved the neutral safety/back up lamp switch to the proper truck location and installed a new set of truck grommets.
It has been completely dissssembled, bead blasted, painted, checked, lubed and set to factory spec. Turn signal switch was disassembled, cleaned and lubed.
New upper and lower grommets
New turn signal and tilt levers.
New neutral safety/back up lamp switch.
$365 shipped, i normally sell these for $435 but i have reduced the price because it is missing the wiring cover at the bottom of the column. $70 should buy you a new cover.....when i install my columns i mount them as far forward towards the dash as possible for extra belly and arm room, if you do that the wiring is barely visible.
randy500 is offline   Reply With Quote
Old 10-03-2019, 06:25 PM   #2
randy500
Re: Tilt column, column shift auto, serviced and painted.
Still available, upcoming is a Real deal truck tilt, column shift auto, on the bench being restored right now....
Old 10-05-2019, 10:09 AM   #3
randy500
I found a lower wiring cover....i can still sell as is or install the freshly painted cover and sell for $435 shipped.
Old 10-05-2019, 11:54 AM   #4
rgunlock
rgunlock's Avatar
I'll take it. I sent you a text.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 10-05-2019, 12:14 PM   #5
randy500
Thanks Rick!
If anybody was on the fence on this column or needs a real truck tilt, im painting a real truck tilt today and also will have another motorhome conversion column ready in a couple of days.
Old 10-14-2019, 10:16 PM   #6
rgunlock
rgunlock's Avatar
Column was delivered in great shape. Looks like a real nice job refurbishing it, and it must have taken you at least an hour to pack it for shipping. Took me almost that long to unpack it Thanks!
Rick
Old 10-14-2019, 10:44 PM   #7
randy500
Glad to hear it arrived safely...i pack them so they can take some shipping abuse...
