Robert Olson Transport
![]() Join Date: Oct 2002
clutch pedal linkages
as yall know i have a 76 C10 that has a 250 I 6 motor in it with the three on the tree. Recently because of rust issues ive replaced the entire cab with a 81 C20 cab.The 81 cab used to be a standard shirt cab too cause the brake pedal is one of the real small onesMy question to you all is is there any difference between the clutch linkages from, 76 to 81 cause i stripped out almost every part i could out of the 76 cab .i want to blot this up as painlessly as possible Do i need to use the clutch assy out of a newer ( 81-87 ) truck?
Ive already swapped over the wiring harness and the column
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
If you are putting the whole assembly in there, you won't have a problem. I put a 73 in my 86 cab for mock up purposes. Techically, as long as you put everything from cabA and put it in cabB, you won't have a problem. It is when you start miss-matching parts that you have problems.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
now i left the metal that was riveted into the cab which the cluthc pedal bolts through( brake pedal too) is that going to make a difference?
#4 | |
You are talking about the large shaped piece just to the right of the firewall clearance right? They will be the same, BUT, depending on the setup of the donor, you might either have 2 holes missing, or 2 extra.
Can you point it out in this pic what you are talking about: ![]() Quote:
the piece of metal i was referring to is the one inside the cab its under the dash and athe column bolts up to it and the brake and clutch pedals go into it
Oh, the complimentary one to the outside. They will be the same, You don't need to "unweld" anything.
