Old 10-02-2019, 11:29 AM   #1
forestb
forestb's Avatar
Bad Speaker Location???
This has always seemed like a bad speaker location. Has anyone tried these?
forestb is offline   Reply With Quote
Old 10-02-2019, 01:14 PM   #2
pheengurs
pheengurs's Avatar
Re: Bad Speaker Location???
those are at the kick panel?
when I bought my truck, the PO had already removed the stock fresh air vents and installed speakers... I replaced em with some mid quality 3 way 6" JL speakers, and then fabbed up a sealing system to keep the elements out of the backs of the speakers...
they sound OK. I'd rather have a more balanced 4 speaker setup with 2 speakers behind the seat, but I still have the factory gas tank so doing that becomes more difficult... and really, my exhaust is in general, so loud and so pleasing to my ears, I rarely use the stereo
please excuse the quality of the photos...
1964 K10 shortbox Stepside
383 sbc stroker under vortec heads
sm420 trans / t221 tcase / corp 10 front axle / corp 12 rear axle / 3.73 gears
rolling on 33x12x15 tires on 6 lug rims.
pheengurs is offline   Reply With Quote
Old 10-02-2019, 01:21 PM   #3
forestb
forestb's Avatar
No they go in the cab corner behind the seat. I also put in some kick panel speakers and I am having a hard time getting to be as lout as my dash speakers.
Old 10-02-2019, 01:41 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
I mounted a pair of 6x9 speakers in that rear lower cab corner...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-02-2019, 01:43 PM   #5
forestb
forestb's Avatar
how do they sound
Old 10-02-2019, 02:22 PM   #6
vin63
vin63's Avatar
Not too bad considering. The wood and curved shape speaker enclosure helps.
Old 10-02-2019, 09:07 PM   #7
cwcarpenter98
cwcarpenter98's Avatar
I wanted some 6x9s but still have the gas tank, so this is what I did. Used existing holes except for the two front screws on the passenger side. The small speaker enclosures were from the previous owner, so I just left them there.
Because I have the wood bolted directly to the metal, I can feel the speaker vibrations through the clutch pedal. Probably going to use a rubber spacer of some sort to try and decrease that a bit. Also thinking of making some sort of enclosure for the speakers just so crap doesn't fall in the backside while driving
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-03-2019, 06:58 AM   #8
Cohi
Cohi's Avatar
I have not tried those but feel you'd still need to have something up front for better stereo imaging. those champers are big, so I'd think youd need a lot of dynamat or other equivalent to knock back the hollow resonance.
i put my front components in the lower door... too boomy - and dynamat wont stick to the inside of the door due to corrosion. I've got the removable metal panel matted up and ran a strip along the lower horizontal edge of the door where you cant see it but it still isnt enough to dampen properly. I'll probably dynamat the lower portion of the door and have my guy cover the mat with carpet.... for now, i've toned down all bass from the fronts and rely upon the subs behind the seat for bass fill. It's aint bad, but it aint right yet either.
thinking kick panels may have been a better solution
Denver/Big Island -- Instagram: Slammed66c10
'46 Fleetmaster Coupe
'64 C10 on Ridetech Air Ride
'66 C10 on GSI Bagged Chassis - in progress
'12 FLHR
'11 Custom Homebuilt Chop/Softail
Cohi is offline   Reply With Quote
Old 12-01-2019, 12:43 PM   #9
pheengurs
pheengurs's Avatar
there are some really great ideas and innovations in this thread... cudos!
has anyone done anything to the roofs of our trucks in the name of better sound quality?
would it make much difference I wonder?
I've been considering adding dynamat to the roof and building some kind of custom covered headliner, that would eliminate the old in cab courtesy light, incorporate led lights, stereo remote sensor, sunglasses pocket, mapholder clip & whatever other good use I can make of that space...
anyway back to the speaker location topic!
- the sound quality of my kick panel location speakers/speaker overall quality and type basically dictate what comes out.
I knew adding a smallish round 3way speaker would cover highs and mids, but not low frequencies...
so I added a cobbled together box for a downward facing 10" subwoofer mounted underneath my center console. which does a decent job of rounding out the sound...
When I'm rolling down the road at highway speed, in the summer, I don't bother turning it on. I've got 33" mud tires howling away, plus 2.5" dual exhaust piped in behind the stepside...
It is not show quality, but it sounds not half bad with the engine off and doors open, parked out in the bush, sitting around a campfire.
Old 12-01-2019, 04:51 PM   #10
LVPhotos
LVPhotos's Avatar
There is no optimal location in a tin can. I have to laugh at people who talk sound quality but won't put the $ in a quality speaker. A behind the seat speaker is not Ideal and as SQ competition there is no sound wanted from rear. If you buy a good quality speaker that can play at higher level, the kick panel is ok. Angle the speakers out towards head. A 6" sub in the right box will out perform 12" in a bad box. 6x9 have fallen in glory but I will say some Motorcycles running Arc Audio or Hybrid Audio 6x9 will make you fork out the $.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-02-2019, 01:20 AM   #11
jweb
jweb's Avatar
I built something similar to these for my ‘51 and used some cheap speakers so they were out of sight and they sound okay. I wasn’t going for high end.
Here is some great info on a high quality system for 60-66 trucks:
http://67-72chevytrucks.com/vboard/s...=Sonic+nirvana
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 12-04-2019, 09:48 PM   #12
rws1012
Was watching Sam's Garage and they used the rear cab corner pieces that Brothers sells. He used boom mat that fit around the speaker and some of it on the metal of the truck. Looked good and said the sounds was real good. Just my 2 cents worth.
rws1012 is offline   Reply With Quote
Old 12-05-2019, 11:15 AM   #13
62 short step
62 short step's Avatar
I just installed those in my 65. Sounds good for the location, just need to install some sound deadening mat or some type of insulation.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 12-05-2019, 08:20 PM   #14
WhippinSaw
WhippinSaw's Avatar
I just used magnetic tape and put them under the seat.
I also bolted 2 really small speakers under the dash.
Speakers did not move around under the seat, and Ok sound for the truck.
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 12-09-2019, 12:26 PM   #15
forestb
forestb's Avatar
Brothers had this on there website
http://blog.brotherstrucks.com/1960-...019+Newsletter
Old 12-09-2019, 12:46 PM   #16
jweb
jweb's Avatar
You might try contacting this forum member, it looks like he makes similar brackets for most other years and his price is better.
https://67-72chevytrucks.com/vboard/...d.php?t=645857
Old 12-09-2019, 01:46 PM   #17
The Rocknrod
Moderator
The Rocknrod's Avatar
I previously asked him if he made them for our trucks and he said No!
Old 12-09-2019, 02:01 PM   #18
jweb
jweb's Avatar
That's too bad. Honestly they're not that difficult to make out of 1/4" mdf which is way better for speaker enclosures than metal.
The ones I made for my '51 are 1/4" mdf that I wrapped in black backless black carpet. It makes them really hard to see, which is exactly what I was going for.
Old 12-10-2019, 12:01 AM   #19
AcampoDave
AcampoDave's Avatar
Here's a cheap and easy holes free headliner that I made. It's still holding fast, but somebody has suggested magnets in lieu of velcro which may provide added holding power http://67-72chevytrucks.com/vboard/s...d.php?t=741002
AcampoDave is offline   Reply With Quote
Old 12-10-2019, 06:55 PM   #20
doobiebro
doobiebro's Avatar
How crazy I just saw a YouTube video on this from Brothers a couple of days ago. Here you go https://www.youtube.com/watch?v=GkX9noK76Bo
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 12-10-2019, 07:05 PM   #21
forestb
forestb's Avatar
See post #15 but thanks anyways.
Old 12-11-2019, 10:32 AM   #22
doobiebro
doobiebro's Avatar
yup didnt see it..
