stepside fender
Is the long bed fender the same as a short bed fender?
Re: stepside fender
Yes
![]() Join Date: Feb 2002
Re: stepside fender
Except for the tire carrier ones. The long stepside fender is different from the short one, which has a bigger cut-out for the tire mount. On the longer stepside, there's more room over the step, so less is cut out of the fender.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: stepside fender
X2, I agree.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Re: stepside fender
And, I have discovered, finding the LWB fender w/ cut-out is much harder than finding the SWB, no doubt a function of production numbers.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
Re: stepside fender
They ARE different! The longbed fenders are longer. A buddy of mine bought some to replace his rusty shortbed fenders, and nothing matched up. They almost touched the rear stake pocket, and the front side pushed the step panel about an inch forward.
Re: stepside fender
This news to me, I learn something new all the time.
Go Pack Go!
Re: stepside fender
Re: stepside fender
Having no experience with the longstep chassis, I can only take your word for it.
I only observed that the spare tire cut-outs were different. GM tended toward uniformity in parts. Could be it's the same stamped fender, but with different spacing for mounting holes. If it is longer, I'd be surprised.
Currently Blazerless
Re: stepside fender
Short, long and even 9ft stepsides all use the same rear fenders and all will bolt right up. Aside from the spare tire cutouts like mentioned.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
Moderator
![]() Join Date: Jun 2017
Re: stepside fender
LMC Truck and many other vendors list one number for right side and one number for left side stepside rear fenders.....
Perhaps the person with the "longer fenders" had a later model set...I see LMC lists a different number for 73 on rear fenders.... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
![]() Join Date: Dec 2009
Re: stepside fender
This can be a Good thread for (documentation) on step-side fenders.
The step-side fenders on my 67 8 foot long wood floor bed The measurement is 61" on the back side of the fender from trim line to trim line. I can post pictures if needed. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#13 |
Old member
I can't see how the fender could be longer on them. The wheel area on the trucks would be the same size just longer in front and back. All the guys cutting the frames never have mentioned having to cut up the fenders. Think about it the wheel opening has to be the same.
I agree the 73 up's may be different though. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#14 |
Moderator
Re: stepside fender
73 - 87 rear stepside fenders are totally different from 67-72 rear stepside fenders...
All parts suppliers I looked up did not list a different fender for short box against long box....regardless of which year range. They all list different numbers within each year range to accommodate spare tire impressions and gas tank holes. 38-9539-T REAR STEPSIDE FENDER-RH 73-87 38-9538-T REAR STEPSIDE FENDER-LH 73-87 38-9554-T REAR FENDER-LH 67-72 38-9547-T REAR FENDER-RH 67-72
