Old 10-03-2019, 08:51 PM   #1
Astro-Balls
Astro-Balls's Avatar
'68 BBC brackets
Any vendors carry the correct Power Steering, Alternator and AC brackets fora '68 BBC ?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 10-04-2019, 09:50 AM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: '68 BBC brackets
These are what I have on my 72. He also has used OEM stands from time to time for $244...There's no difference in the stands other than the new pair is stamped abroad and go for $99. My truck has a very nasty frame twisting 439ci BBC in it and the $99 dollar stands work great. I also use standard small block Chevy motor mounts with over size hardened washers to pin her down. The SBC motor mounts use a 1" 7/16-14 NC grade 5 bolt. https://www.manestruckparts.com/stor...Category_ID=16 Heres the SBC mounts, they work just fine as long as you use a hardened washer with the correct bolt. https://www.manestruckparts.com/stor...Category_ID=16
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
