Gas Gauge or Sending unit
Greetings to all,
I am hoping to help get the next in a long line of issues settled on my son's truck. It is a 69 step side. The issue at hand right now is the gas gauge or sending unit. Just to backtrack, I have replaced all the wiring with a brand new setup. American Auto Wire I think is the company. The box is in the garage and it is too cold for me to walk out there. LOL. Anyway, I checked the wire that hooks up to the sending unit and I have power there. When I plug in that wire and plug in the harness to the back of the cluster the gas gauge does not move. The gauge cluster has a new circuit board, so I don't think that is the issue. I used a square batter, 9 volt I think, out of my meter and clipped a the positive and negatives with a wire. Ran those wires to the posts on the gas gauge and the needle moves left and right depending on what I posts I have the wires clipped to, if that makes sense. So, my thought is the sending unit is bad. Am I on the right track? I searched the forum, and somebody posted that if I use my ohmmeter and touch the positive post and ground to the sending unit flange I should get some sort of reading. I am going to try that once it gets light enough to see. Any thoughts or suggestions would be most appreciated. Again, it is all new wiring and I have power to the wire that clips into the gas tank itself. So I am leaning towards the sender. Thanks in advance for any help. Dino AKA Dj's dad. LOL. |
#2 | |
The Older Generation
Re: Gas Gauge or Sending unit
LockDoc
#3 | |
Ok. I am not trying to be a smart ass. Just trying to understand. Here is the wire I'm talking about. It runs into the dash gauge cluster that plugs into the back of the dash.
I thought that was how the gauge got the signal from the sending unit. Am I off?
![]() Join Date: Dec 2009
https://www.youtube.com/watch?v=5Lt6mHrvuow
https://www.youtube.com/watch?v=MZhbdl95yCI Here is a couple of videos Hope this helps. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Guest
Posts: n/a
There are lots of good threads on the Forum as well ( I need to review them as I have issues with mine. “The coldest winter I ever spent was the summer I spent in San Francisco.” Mark Twain. So true!
Awesome. Thanks. When plugged into the gas tank, the gauge does not move at all. I did a test with a 9 volt batter, hooking up the positive and the negative to the back of the gas gauge and it moved the needle. So, I am thinking the gauge is working and the sending unit is not. If the gauge were bad, wouldn't the needle not move when the small test battery is plugged in? I am just trying to diagnose the issue before I go and spend 25 to 30 bucks on a new sending unit.
I plan on putting the ohmmeter on the sending unit as stated above and see what happens as well, so more posts to come LOL. Thanks for all the help guys. Trying to just get this thing going for my son while he saves up money to get a new tank that will mount in the bed. |
OK, so I took the gauge out of the cluster and tried using my ohm meter. Please excuse the stupidity of my post. When I touch the two terminals on the back of the gas gauge they register on the meter, but work their way down to zero. Is that normal? I don't recall ever using the ohm meter on my tester, so I am not sure I am doing it right. Any assistance would be most appreciated. I am still leaning towards the sending unit though.
I would remove the sender from the tank and test it.
Hook the leads up then move the float up and down. Check the float for any holes that would also make the sender not read. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 10-04-2019 at 01:52 PM. |
#12 | |
#13 | |
I don't know how the AAW loom is wired but the wire from the sending unit plugs into the fuse block on the original wiring. If you look at the picture you can see the FUEL GA terminal on the right side of the fuse block. The original wire is tan. LockDoc
#14 |
Post Whore
![]() Join Date: Feb 2016
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#15 |
![]() Join Date: Aug 2019
I didn't see any ground wire at the tank sending unit. It has to be grounded. If you had 12v at the sender wire (tan ) you probably don't have any ground.
#16 | |
I am gonna fool with it today and see what I can come up with. Thanks. |
#17 |
I hate to appear stupid, but what the hell. LOL. I put the tester on the posts on the back of the gauge. They read, but then run down to zero. Is this supposed to be? Am I screwing something up.
#18 |
Update to at least part of the issue. I lowered the setting on my meter to 20k. When I touched the probes to the left and right posts on the gauge I got a .04 reading. Then I touched the left to the bottom post and the right to the bottom post on the gauge and got .10 each time. Could it be that the meter was just set too high to get a reading? I am going to pull the sender later on in the week, when I am off work and check that the way you all have told me, but I am happy to at least get a reading on the meter. LOL.
Thanks to all who helped. RR |
#19 |
![]() Join Date: Oct 2013
Maybe check the brass float on the end of the sending unit arm for leaks. If it's really old or even fairly new the solder joint could be compromised. You can shake it around when u remove the sending unit from the tank and if you hear sloshing inside then you know its trash. And based on my own personal experiences, you might consider switching to a plastic float. They practically last forever and no solder joint to worry about. I actually just bought one yesterday for my dads 64 c10. $4 on summit. $10 to ship.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
#20 | |
Thanks to all who posted replies, I really appreciate the info. My son would love to use the stock gauges, so this is a good start. RR |
#21 |
Well, the problem has been solved. I took out the sending unit,and low and behold it works. A simple inspection of the float finds it to be cracked and worn. So, now off to find a new float. Problem is, it is a 5.00 part and 10.00 shipping LOL. Must be some other way to do this, right? Any help here would be much appreciated, but it is nice to know the gauge and the wiring seem to be working out just fine. RR
#22 | |
Thanks, LockDoc
#23 |
Amazon is where I buy them. Free shipping baby.
https://www.amazon.com/Omix-Ada-1772.../dp/B003AOM17I |
#24 | |
OK, sorry, I thought if that was just if I was trying to sell something. I figured if somebody had one laying around and wanted to get rid of it, I would rather give the money to a board member. Won't happen again, I promise. |
#25 | |
thank you so much for the link. I appreciate it RR |
