1971 C10 402 Big Block Turbo 400 Complete with Radiator and Fan Shroud
Just removed from a 1971 Chevrolet C30.. this is complete with accessories and accessory brackets ( a/c, power steering, alternator) exhaust manifolds also includes Turbo 400 transmission. Will also include kickdown switch wiring and can include motor mounts and towers. Four core radiator with fan shroud with mounting clips and upper mounting brackets also! Unknown running condition as it was parked after returning from a trip that required a dealership stop to repair a slipped timing chain.
$1650 Located in Riverside, CA 92508 May be willing to part it out....but would like to give it time as a whole first |
On the road
![]() ![]() Join Date: Jan 2004
Re: 1971 C10 402 Big Block Turbo 400 Complete with Radiator and Fan Shroud
If you are interested in parting it out I would like the fan shroud
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
On the road
That would be great, thanks
