Old 10-04-2019, 10:26 PM   #1
DD1
WTB Power Brake Booster Push-rod hardware
Looking for the hardware needed to attached the push rod to the brake booster bracket, with or without the pushrod itself.
Here are pics of what I have now. I need the parts to connect the pushrod to the booster bracket.
___________________________________________
Darien
1971 C10 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=502964
DD1 is offline   Reply With Quote
Old 10-05-2019, 12:05 AM   #2
Madkidd007
Madkidd007's Avatar
Re: WTB Power Brake Booster Push-rod hardware
I’ve got what you need, I’ll be taking it from a complete setup, so hows $12.50 shipped? Have everything else also if one of your pieces isn’t in good condition.
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 10-05-2019, 04:54 PM   #3
DD1
For $12.50, I really can’t say no to that. Are you including the pushrod or just the connecting hardware? If the pushrod is not included, would you mind measuring it so I can compare and determine if I need to get it also?
Thanks!
Darien
1971 C10 LWB
Old 10-05-2019, 06:17 PM   #4
Madkidd007
Madkidd007's Avatar
That’s just the hardware, just measured and it’s 9.25” center to center. Last time someone asked about the rod I told them $29 shipped.
I’m in a good mood so if you need both $27.
Also I assume since you have a rod already then you have the correct pedal to rod bolt, but if not then $30 for the rod and attaching hardware on both ends. Needless to say whatever option you choose
Old 10-05-2019, 06:24 PM   #5
projectking
projectking's Avatar
Those rod bolts like to disappear and turn up once you’ve replaced it!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 10-05-2019, 06:52 PM   #6
Madkidd007
Madkidd007's Avatar
No kidding, exactly why I tape or zip tie stuff together now.
Old 10-05-2019, 10:03 PM   #7
DD1
Thanks! I will go measure as soon as possible. I would assume that if I have the correct pushrod, then I have the correct pedal-to-rod bolt. But I will take a pic and post just to be sure.
Darien
1971 C10 LWB
Old 10-05-2019, 10:17 PM   #8
DD1
My pushrod measures 9.25 inches and it looks like I have the correct pedal to rod bolt. I will take the hardware, please. I plan to try and get it setup in the next couple of weeks, so if I need anything else, I will let you know.
Assuming my booster ends up not being good, is yours for sale?
You take Paypal for the hardware?
Thanks. I appreciate the help.
Darien
1971 C10 LWB
Old 10-05-2019, 11:25 PM   #9
Madkidd007
Madkidd007's Avatar
My paypal is in my signature, just make sure you do goods & services. And to be honest I have no clue the condition of my booster
Old 10-06-2019, 11:53 AM   #10
DD1
I just sent you $13 to cover your Paypal fees as well. Thanks for your help with this.
I thought I had included the photo of the pedal to rod bolt in the post. Here it is in case I am mistaken.
Darien
1971 C10 LWB
Old 10-06-2019, 12:25 PM   #11
DD1
Hey Madkidd007, do you know what type of bolts I would use to attach the bracket to the firewall? As you can see in the pic above, two of mine are broken.
Thanks!
Darien
1971 C10 LWB
Old 10-06-2019, 02:25 PM   #12
Madkidd007
Madkidd007's Avatar
Thanks!
I have never seen one back off but just Incase since it has a hole, throw a cotter in there or even a nail just as a backup before you drive it. It’s been a while on the bracket since I’ve looked, I thought they were pressed in studs in the pedal support. If you look at your picture you can barely see what appears to be knurles on the bolt on the inside of the firewall.
Old 10-06-2019, 07:52 PM   #13
Madkidd007
Madkidd007's Avatar
Confirmed they are studs and are tack welded in. Kind of a pain under the dash. Probably would be easiest to pull your brake pedal support if your truck is complete and don’t want sparks flying inside
Old 10-06-2019, 08:02 PM   #14
Madkidd007
Madkidd007's Avatar
The second one I nicked with the grinder and the threads need to be cleaned up. If you want them, send me $5 and I’ll send them too. Worked up more of a sweat than at work all day
Old 10-07-2019, 11:07 PM   #15
DD1
I appreciate the effort, but I'll pass. I'll just replace them with a bolt and washer. I was thinking of using a grinding stone on a dremel to take off the weld. Truck is nowhere near complete. Just want to be able to turn it and stop it.
Darien
1971 C10 LWB
