10-05-2019, 10:58 AM | #1 |
What is this for?
Replacing an old holley carb with an edelbrock 1406 and this is in the way to where its just enough for me not getting the edelbrock carb lined up correctly. Not sure what I need to do to get the carb lined up correctly with the bolt holes.
10-05-2019, 11:02 AM | #2 |
Re: What is this for?
Never seen a dual stage EGR valve on a small block.
BTW that's an EGR valve. Smog inspections where you are? Remove and plug, or get a manifold without the EGR ports |
10-05-2019, 11:02 AM | #3 |
It’s an egr.
Exhaust gas recycle. You can remove it and cover the hole with a flat plate and gasket. |
10-05-2019, 11:04 AM | #4 |
Thanks guys, im in Texas so no smog issues in my part. I'll get it removed. Im assuming any parts store will have a plug that will fit?
10-05-2019, 11:06 AM | #5 |
You might need to make a plate yourself.
10-05-2019, 11:26 AM | #6 |
So,, what else you got???
Yes, you will have to fab your own plate, but they are relatively easy.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks.... Sorry, we CANNOT ship larger parts. Thanks.
10-05-2019, 12:39 PM | #7 |
I believe the 1406 is a square-bore carb. You're going to want to replace that manifold anyway.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-05-2019, 02:24 PM | #8 |
YOU'LL NEED AN ADAPTER TO GO FROM SPREADBORE TO SQUARE FOR THE CARB AND YOU CAN BUY A BLOCKOFF PLATE FOR THE EGR. https://www.holley.com/products/fuel...ers/parts/1932 AND...https://www.holley.com/products/fuel...ies/parts/7631
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
10-05-2019, 02:29 PM | #9 |
I don't think anybody makes a block off plate for that clamp type. Manifold would be the best solution all around. On a budget? Remove the valve and see what it will take to plug both the vacuum hole and the exhaust blow hole. If I remember correctly, those manifolds were prone to cracking through the cross over anyways
10-05-2019, 05:01 PM | #10 |
Moderator
Perhaps this relocation plate from Edelbrock will work for you...
https://www.summitracing.com/parts/e...6/applications
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-05-2019, 05:28 PM | #11 |
An Edelbrock 2701 aluminum intake manifold for square bore carbs is only $148.95 from Summit, Jegs, or Amazon.
10-05-2019, 09:19 PM | #12 |
Or keep the intake and buy a Quadrajet for $199.
10-05-2019, 10:00 PM | #13 |
That would actually be my choice. It's a much better carb, and you'll save a whole bunch of headaches. National Carburetors has a pretty good price on completely remanufactured Quadrajets.
10-05-2019, 10:16 PM | #14 |
Yes, I bought their part number ND4478 with the electric choke. In my message above I should have said $279 because there is a $50 core charge and shipping, and not having a Quadrajet before probably means no core charge returned. Still very good carb and reasonable price.
