Old 10-05-2019, 11:35 AM   #1
Ofnaman1
fuel pump an fitting
The more I look, the more confused I get.... Anyway, I am looking for a adapter fitting for my stock fuel pump. I am putting -6 an hose from the pump to carb. I have bought the wrong fitting for the pump 2 times now and can use help on getting the right one. If you know what fitting I need to convert the outlet on a stock pump to -6an male, please chime in. Thank you.
Ofnaman1 is offline   Reply With Quote
Old 10-05-2019, 11:55 AM   #2
geezer#99
geezer#99's Avatar
Re: fuel pump an fitting
Can’t help with a part number but you could try taking the pump and hose to your sorta local summit racing store and match them up.
Old 10-05-2019, 01:01 PM   #3
rcazwillis
1/2-20 inverted flare to -6an, maybe. What 2 have you bought that are wrong?
Carter pump shows 1/2-20 inverted flare.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 10-05-2019, 04:26 PM   #4
randy500
3/8 hard line or 5/16 hard line? Should be 3/8 an dif so the fitting is 5/8-18 male inverted flare
Last edited by randy500; 10-05-2019 at 04:31 PM. Reason: Corrected from 9/61 to 5/8-18
randy500 is offline   Reply With Quote
Old 10-05-2019, 04:31 PM   #5
randy500
Here it is
https://www.speedwaymotors.com/-6-AN...yABEgJqj_D_BwE
