Old 10-05-2019, 02:29 PM   #1
cgster
Replace pcv grommet
Is there an easy way to replace the pcv grommet without removing valve covers?
cgster is offline   Reply With Quote
Old 10-05-2019, 02:32 PM   #2
kwmech
Re: Replace pcv grommet
small flat blade screwdriver down the side of the grommet and pry it out. Unless it is hard as a rock and cracked, then it will come out in pieces. After that you can pull pieces out of the hole with some needle nose pliers
Old 10-05-2019, 02:40 PM   #3
cgster
How to put new one in?
Old 10-05-2019, 03:43 PM   #4
geezer#99
geezer#99's Avatar
Lube it liberally and rotate it in to place.
I use wd40 for a lube.
Some stubborn ones I’ve had to cut a small notch in the bottom lip for a starter point.
Old 10-05-2019, 04:58 PM   #5
kwmech
You don't have to cut anything, the new one will be pliable enough to twist and wiggle in
Old 10-05-2019, 08:41 PM   #6
weq92f
weq92f's Avatar
You can also put the grommet on your pcv valve or vent and use that as an install "tool" to get it in there. Careful you don't break the tool though.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
