How to hook this all up?
How do I hook up my valve cover PCV, brake booster, and the vacuum advance on my hei distributor?
Am I missing a coupler/nipple on the brake booster? I dont know what to plug into the ports on the carb...
1968 GMC 3/4 Ton 4x4 K20 / 2500 1971 Chevrolet Chevelle Malibu |
Re: How to hook this all up?
Are those the only ports on the carburetor? Plus can you get the model number off the carb. It should be on the air horn.
Edit: I was looking closer at your intake manifold and what I circle is the mounting spot for a divorced choke. So to have a working choke you can convert to an electric choke or rig something up. I have rigged one by wrapping copper tubing around the exhaust manifold. The air in the tube just needs to be heated. It did not look pretty, but was cheap and worked well enough. I made it with stuff in my garage, when I had more time then money.
AJC Last edited by AJC; 10-06-2019 at 01:36 AM. Reason: Identify part wrong |
![]() Join Date: Mar 2003
First thing I would do is swap the valve covers so the oil fill is in front. Second I'd remove the brake booster fitting from the valve cover and put it where it belongs
![]() Join Date: Jan 2001
I've never understood why anyone (sometimes including the facory) would put an oil fill anywhere but the most accessible place. Unless you don't plan to drive the vehicle, you're going to need access to that thing at regular intervals.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
AJC is right on! Your passenger side valve cover has no provisions for a breather valve. So even if you hook up the PCV on the drivers side, it won't work right because there's no cross air flow. You need a breather on one side and PCV on the other. A new valve cover is in order, or make a hole. Also, as kwmech mentioned, the brake booster check valve is what you're missing and it's the white connector in your PCV hole now. Take it out of the PCV hole and place it back in the booster "C" where it belongs.
For vac port "A", you'll need to install a tee to hook up a couple things there. If you have an auto trans, the modulator connects there as well. For the vac advance, GM engineers found manifold vacuum is best, but you have to setup the distributor for it. It's not a simple hose swap. Read the following article, it goes over timing and vac advance. http://www.camaros.org/pdf/timing101.pdf Last edited by 68 P.O.S.; 10-06-2019 at 10:16 AM. |
