Old 10-07-2019, 09:23 AM   #1
Dan-K
Parts to add Booster ?
Other than the Booster and prop valve are there any other parts that are required to add a booster to a non power brake truck . My truck has discs in the front but there is no booster . I think my master cylinder is toast so I figure I would just purchase the Master/Booster assembly and kill two birds with one stone . Thanks in advance .
Dan-K is offline   Reply With Quote
Old 10-07-2019, 03:04 PM   #2
67/Heaven
67/Heaven's Avatar
Re: Parts to add Booster ?
The booster, the master cylinder, the proportioning valve, there is also a firewall dust boot that my set up came with, finally you will need some fittings and some hose to hook up the booster to the engine vacuum. Keep in mind that you will have to do some modifications on the brake lines to get them to line up as the connection points will change slightly in physical location. I ended up bending new sections from the proportioning valve, i used 1/4" stainless steel Swagelok fitttings to tie in to the old lines.
67/Heaven is offline   Reply With Quote
Old 10-08-2019, 07:28 AM   #3
Mike C
Mike C's Avatar
67-72 trucks use offset brackets and a linkage to actuate the booster. It raises the centerline of the master above the pushrod where the manual one mounts.
I would buy a conversion setup on eBay or form one of the providers. I recently picked one up from Speedway Motors FWIW.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-08-2019, 09:06 AM   #4
Dan-K
Thanks for the info .
Old 10-08-2019, 11:26 AM   #5
randy500
No need for a proportioning valve, you already have one.
No need to bleed the brakes either or touch the lines.
Remove the master cylinder, prop it up on the engine, install the booster
The bolt at he pedal is the same one as non power.
You should install a new rubber boot at the firewall
Bolt on the booster and connect the pedal.
Bolt the mastercylinder with lines and prop valve attached to the booster, pulling it forward stretching the brake lines, there is plenty of play in the lines.
Connect vacuum to the booster.
Your carb should have a fitting at the rear, 1/4” npt plug, get the adapter fitting and hardline etc to the booster.
randy500 is offline   Reply With Quote
Old 10-08-2019, 11:29 AM   #6
randy500
There are basically 2 styles of master cylinders, deep hole or shallow hole and boosters must match. 71-2 3/4ton is shallow, the rest are deep.
Old 10-08-2019, 09:33 PM   #7
Mike C
Mike C's Avatar
The 8" aftermarket booster setup I bought came with a master cylinder spacer. Run the spacer for a shallow setup and leave it out if you need the deep. That is convenient.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-08-2019, 10:56 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Parts to add Booster ?
I would buy a complete setup as you stated. If the master cylinder is bad buy it all as a unit. Stay away from the CPP proportioning valve with rubber boot plunger.
Some of the booster's had a bracket arm also but it's not a must have.
If you have the room go factory 11" booster.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-09-2019, 09:23 AM   #9
Dan-K
I have ordered the complete setup (master/booster/prop) so It should be easier that way .
