10-07-2019, 04:07 PM | #1 |
400 sbc dripping antifreeze
I built and warmed over up a 76 2bolt main 400 for mild towing duty in my 72 c20. About 2000 miles on motor I notice an antifreeze drip . Crawled under it to try to find leak . Antifreeze is dripping (few drops/minute) off of bottom of starter bolt on the engine/center line side . Any ideas on source of this . Without having pulled starter I am guessing cracked block ? ? ? Any/all thoughts welcome .
10-07-2019, 04:20 PM | #2 |
Re: 400 sbc dripping antifreeze
Rear intake corner, back of head gasket, rear freeze plug. Pressure check and find out
10-07-2019, 06:43 PM | #3 |
Moderator
Sounds like rear freeze plug has sprung a leak....or the rear of the manifold / head where the water jackets meet the manifold....
I assume you drilled the steam holes in the heads if they were replaced....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-09-2019, 07:59 PM | #4 |
I am also thinking the Freeze plug, I just had to replace the two under the motor motor mounts on my 400sbc...rusted out..
1972 Chevy C10 400sbc 4sp Matthew 4:19 And he saith unto them, Follow me, and I will make you fishers of men. |
10-09-2019, 08:40 PM | #5 |
Moderator
I always use brass freeze plugs in a build or in a replacement scenario....seal them up with a little Permatex then forget them forever....
Cost a little more but way better IMO. Only steel ones I use are cam bore end and lifter gallery plugs...
