10-07-2019, 08:21 PM | #1 |
Guest
Posts: n/a
WTB: 72' K10 Factory Sport bumper and brackets
Rear Bumper—Given that my truck is being restored in the Sacramento area, I would prefer if the part were in that general area. Thanks in advance.
10-09-2019, 12:30 PM | #2 |
Go Pack Go!
Re: WTB: 72' K10 Factory Sport bumper and brackets
I don't have what you're looking for but stating front or rear would help out.
I have a set of Short bed GMC front bumper brackets but those are truck specific. |
10-09-2019, 06:20 PM | #3 |
Well being a sport bumper I’d naturally assume that means rear. Keep in mind 67-72 are the same on the rear brackets and sport bumper. I “believe” the swb leaf 2wd trucks use the same brackets but all 4wd including 67-71 blazers will interchange also.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
10-09-2019, 08:12 PM | #4 |
Guest
Posts: n/a
So the bumper interchanges on a 72 despite the 72 having the frame horns?
10-09-2019, 08:27 PM | #5 |
Correct. The bumper and outter brackets are the same as previous years. I thought at first you meant brackets because your frame had been cutoff. But the horns match the bumper profile. So in your case any sport bumper and outter brackets from 67-72 will work. Just the inners are different, 99% sure on that
10-10-2019, 07:26 AM | #6 |
SWB 4x4 Collector
If you are talking 4x4 rear brackets, it depends on swb vs lwb. Short is 69-71 blazer/swb leaf spring. They are modified from the factory on the inner brackets. 72 blazer just uses the outer brackets as the frame is stamped to be the inners.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
