Old 10-07-2019, 10:40 PM   #1
69Tom
One rocker removed...
So, I was doing some reading here on the forums and saw someone recommend that if you’re replacing rockers, it’s better to first pull the cab and put in new body bushings if yours are worn out. Well mine are worn out. Problem is, I didn’t read the article until after I had cut out the rocker on the passenger side.
So do I a) install the new rocker and then pull the body, or b) pull the body now without the rocker?
Thanks.
69Tom is offline   Reply With Quote
