Old 10-08-2019, 09:38 AM   #1
ozkiwi
Starter issues again
I installed powermaster gear reduction starter about a year ago and all has been fine until it started just giving a click from the solenoid sometimes when turning the key and firing up without issue other times.It will start with 2 or 3 tries sometimes and others just solenoid clicks and wont start for 20 minutes or so .I thought it was heat related but has done it a couple of times from stone cold in the morning and started fine from with the motor well and truly hot.
I have ordered a heat shield for the starter but it does not act like a heat problem.Any other suggestions?
https://www.summitracing.com/parts/pwm-9200
ozkiwi is offline   Reply With Quote
