WTB: Rear Frame Cut
The passenger side rear portion of the frame of my '70 C10 SWB 2WD was poorly repaired by the PO. I'm planning to repair it correctly this time. I'm looking for ~24" of frame behind the crossmember behind the rear axle. The crossmember is riveted to the frame about an inch or two forward of where the frame becomes horizontal after the rear axle hump.
For a SWB frame, I need everything behind the crossmember. If from a LWB frame, I only need ~24" of length starting at that crossmember. I found a picture online and marked up the portion I need (only need the passenger side). If you have anything please let me know condition and the cost shipped to 06410. Thanks -Gen Last edited by mtnbikerxt; 10-08-2019 at 10:01 PM. |
Re: WTB: Rear Frame Cut
I have a 70 gmc c20 frame if your interested. It has leaf springs, not sure if rear part is different.
1972 3/4 ton 402/400 1971 k20 lwb 8.1.4l80.np205 w/37" tires and 6"lift |
![]() ![]() Join Date: Jan 2015
I have a long wheel base frame I can check condition of this area and post pics tomorrow
Got a 1/2 ton previous from CO, and a 3/4 previously from NV. Let me know if the others don't pan out.
LILREDGMC |
No pits or rust it’s looks scaly in the pics but it’s just peeling undercoating $60.00 shipped plus PayPal thanks ......Jeff
This is a 1/2 ton 2wd frame
