10-10-2019, 12:35 AM | #1 |
Active Member
Vortec 350 Throttle Bracket Help
Hello, I'm running an Edelbrock 7116 performer rpm intake manifold and it doesn't seem like the stock throttle and transmission kickdown will bolt onto it - after some digging on the site it seems the Edelbrock bracket 8032 bracket is junk and incompatible? Any advice on the best bolt on strategy would be much appreciated.
Truck is a 72 K1500 |
10-10-2019, 08:17 AM | #2 |
Re: Vortec 350 Throttle Bracket Help
Which carb?
10-10-2019, 09:45 AM | #3 |
i went through this with my crate motor, since the vortec bolt pattern is different the stock bracket will not work as you found out.Since i am using a Holly carb I am using this one from Holley https://www.summitracing.com/parts/hly-20-95/overview/
However i do not have the kick down cable hooked up it dose not adjust to the correct length and manually down shift. I did buy this one https://www.summitracing.com/parts/tfs-20000/overview/ from trick flow but have not used it yet . I have tried the cheap universal ones and modified the Edelbrock ones and all were pretty much crap Good luck ,
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
10-10-2019, 11:03 AM | #4 |
Active Member
I’m using the Edelbrock 1906 AVS2 650 carb
10-10-2019, 12:23 PM | #5 |
I'm running the same carb, though with the 2116 Edlebrock intake.
I got the "Spectre Performance 24283 Throttle Cable Bracket" off amazon and it's done the job. Feels a little flimsy, but I have had no issues with it.
72 C20 with a 350 She's green like the Hulk, but the only thing she smashes is my wallet. |
10-10-2019, 03:14 PM | #6 |
Check out TCI I bought a bracket for my quadrajet when switching to a 200r4 trans.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
