Old 10-10-2019, 09:03 PM   #1
May70
May70's Avatar
Does lmc (or?) make these frame pieces?
Pulled my bed off today.
I need the cross members labeled 1 & 2 and also brackets 3 &4. Maybe I am missing it but ive been searching lmc for them and cant find it.
#1 is definitely toast
Maybe Im searching for the wrong words.
May70 is offline   Reply With Quote
Old 10-10-2019, 09:45 PM   #2
randy500
Re: Does lmc (or?) make these frame pieces?
I have a nice used rear crossmember for $100 shipped, i might have the other one too.
randy500 is offline   Reply With Quote
Old 10-10-2019, 09:52 PM   #3
Grumpy old man
Grumpy old man's Avatar
I have 1/2/3 on the bench and I think #4 on a parts truck out side . If you need them I can list them In the parts section .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 10-11-2019, 04:26 PM   #4
Grumpy old man
Parts /cross members . If you need them let me know and I'll post them on the parts board .
Old 10-11-2019, 04:39 PM   #5
May70
May70's Avatar
Upon further inspection today... saw this close up. Is this all one piece? What are your suggestions to do about the rot between those layers? Need help
Old 10-11-2019, 09:41 PM   #6
ApacheNick
If you have a sand blaster, the first thing you should do is clean up as much of that frame as you can. That's the best way to know what you have left to work with.
From what I can see in your pictures I would be looking for a different frame.
Nick
1961 Apache short stepside 4X4 SBW 348/4 speed
1960 Apache C-20 long fleet custom cab BBW 283/4 Speed
1967 rust bucket Olds Cutlass with a 455
1972 GMC K-15 350/4 speed long fleet
ApacheNick is offline   Reply With Quote
Old 10-11-2019, 09:52 PM   #7
May70
May70's Avatar
The unfortunate thing is the front half is in great shape from what little ive seen because it was covered in oil....
I found a guy by me who might have a good 3/4T frame for 200. He said he would get back to me... Hopefully he still has it. But if not im trying to get a game plan to salvage what I have here.
Old 10-11-2019, 10:42 PM   #8
Grumpy old man
If you don't find one close to you I have this one that's pretty clean .
Old 10-12-2019, 07:48 AM   #9
bigmac73
bigmac73's Avatar
may,
there was a Yellow 71 on the facebook market place this week in Hampton I believe for around 700 bones, might be good for a parts truck or just need some TLC
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-12-2019, 07:51 AM   #10
bigmac73
bigmac73's Avatar
I would find a rolling frame,
I used to deal with a guy named Ron in western branch area, that had a back yard full of chevy parts and old Pontiac stuff too, he was a regular on craigslist . I have not seen him on in a while you might get lucky if you try looking on CL
Mike
Old 10-14-2019, 12:51 PM   #11
May70
May70's Avatar
Ended up finding a great frame for 200 bucks. Looks like real light surface rust and all the mounts, cross members are in good shape. No repairs that ive seen so far. Thanks everyone.
