10-12-2019, 10:36 AM | #1 |
Did any 67-72 have heater hose connection @ radiator?
My '69 CST20 w/350 has a radiator w/heater hose nipple on the right near the top. I don't believe it's original to the truck. The hose connection is blocked off and the heater uses the water pump and intake manifold connections. Is this correct? Also when I had the water pump off noticed the bypass hole has a factory block off dowel in that bypass hole. Thoughts??
Steve weim55 Colorado |
10-12-2019, 10:57 AM | #2 |
Re: Did any 67-72 have heater hose connection @ radiator?
My '69 CST20 w/350, A/C and original 4 row radiator does not have a nipple on the radiator. The original water pump didn't have any bypass provisions. However, if you ever change to a Vortec engine you'd need a bypass.
10-12-2019, 01:06 PM | #3 |
Probably a replacement radiator. Some big blocks used the radiator fitting 73 up.
10-12-2019, 02:45 PM | #4 |
I have seen them like that on a few trucks over the years I think they were all 4 core radiators...
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
10-12-2019, 03:32 PM | #5 |
20' Daredevil (Ret)
The outlet hose from my heater core goes to that radiator nipple on my '72 K20 with factory A/C.
10-12-2019, 03:35 PM | #6 |
10-12-2019, 09:40 PM | #7 |
My 72 K10 air truck also has it too
10-12-2019, 10:12 PM | #8 |
Hmm. The return line on my 71 BBC with A/C connects between the heater core and radiator. Seems I saw an image in the assembly manual of both examples, one to the radiator, the other to the water pump.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-12-2019, 10:13 PM | #9 |
Junior Member
My 72 C10 has a heater hose going to the radiator near the top on the passenger side. Pretty sure it's the original radiator. It's a factory AC truck.
10-12-2019, 10:25 PM | #10 |
I believe some did. Here's a thread to help. http://67-72chevytrucks.com/vboard/s...d.php?t=634002
10-13-2019, 02:38 PM | #11 | |
10-13-2019, 02:40 PM | #12 | |
