Old 10-12-2019, 01:36 PM   #1
kens65fb
Check out these side mouldings
Custom side mouldings
kens65fb is offline   Reply With Quote
Old 10-12-2019, 03:17 PM   #2
bigmoe
bigmoe's Avatar
Re: Check out these side mouldings
Could you do that with a stock set of mouldings?
bigmoe is offline   Reply With Quote
Old 10-12-2019, 06:48 PM   #3
jayoldschool
Moderator
Yes, just install the lower one on an angle and lower back on the door to compensate for the angle. Use shortened long bed trim on the box for the same reason.
jayoldschool is offline   Reply With Quote
Old 10-14-2019, 04:34 PM   #4
forestb
forestb's Avatar
you will have to bend it a little for it to fit the curve of the body which is not there on the trim that goes straight back.
forestb is offline   Reply With Quote
Old 11-11-2019, 11:05 AM   #5
sstock
sstock's Avatar
Dont forget to use the 57 gold filler panel between them to make it look killer
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
