Old 12-04-2003, 12:02 AM   #1
68jimmy
68jimmy's Avatar
question on leafs between 1/2 and 3/4 ton
I'm wanting to replace the suspension setup on my lwb gmc 3/4 ton with a 1/2 ton setup... I think I have the front figured out but I have a question or two about the rear.
1. Will the rear leafs from a swb fit?
2. Can I use the original heavy rear axle with the lighter springs until I find a suitable donor?
3. Is there any good site out there that outlines a 3/4 to 1/2 conversion?
Thanks in advance!
donovan
68jimmy is offline   Reply With Quote
Old 12-04-2003, 02:55 AM   #2
elmono
Be sure to measure the rear spring leafs from eye to eye, as the 3/4 leafs might be 56" whereas the 1/2 leafs might be 52".
Chad
1985 GMC K1500 350 700r4 NP208 3.73
elmono is offline   Reply With Quote
Old 12-04-2003, 06:27 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
What year truck? 2wd or 4wd?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-04-2003, 12:38 PM   #4
68jimmy
68jimmy's Avatar
It is a 68 LWB 3/4 ton 2WD...
tx.
Old 12-04-2003, 03:22 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
You'll need to use springs from a 67 or 68 as the 69 and newer are different. You could just remove a leaf or two. SWB/LWB would have the same length/centering pin location.
Old 12-04-2003, 05:10 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
ive done the reverse swap on the newer generation trucks.. the u bolts are different but if ya use the half ton ubolts with the half ton springs it works out fine
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
