10-13-2019, 08:12 PM | #1 |
Radiator leaking for top area
Not 100% sure, but from what I can tell my radiator is leaking from the bottom of the fill neck. Is there anything I can put around the neck where it meets the radiator that will hold and keep it from leaking?
10-13-2019, 09:20 PM | #2 |
Re: Radiator leaking for top area
That looks like a brass radiator, which means it can be soldered. You'll need to clean off all the paint in the area. Use an acid flux and plenty of heat.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-13-2019, 10:24 PM | #3 |
Would JB Weld hold/seal it?
10-13-2019, 11:49 PM | #4 |
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
10-14-2019, 05:30 AM | #5 |
Location: Herculaneum MO (20 minutes south of St. Louis
X2 ^ it's not that difficult & will save you a lot of money compared to taking it to a shop
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
10-14-2019, 10:43 AM | #6 |
Haven't done any soldering before but will give that a try. Would it be a problem leaving radiator in Truck and not draining the antifreeze out or would I need to drain? Thanks.
10-14-2019, 10:52 AM | #7 |
Its best if you leave the coolant in as lomg as the level is lower then the area you are going to solder. Read up on soldering real good. The area has to be clean. Get a small tube of flux to make it flow good. Most solder has flux in it but its not enough for something like that.
George |
